Modding Uber Keyboard (not just LED's and a paint job)
Discussion in 'Modding' started by Jerm, 12 Aug 2005.
  1. B3CK
    B3CK Minimodder
    14 Jun 2004
  2. Jerm
    Jerm What's a Dremel?
    12 Aug 2005
    Update 8/16/05
    OK, pics are up of the past 3 days of work. Not a whole lot to show, and I know the workmanship isn't that great but im no professional (trying though)
    LCD and USB adapter
    keyboard with metal covering for keys (everything will fit)
    Generic shot of back-right-top
    bottom, with HDD, mouse reciever, and bondo
    not the best bondo work, but decent
    re-wiring is more or less done
    top cover painted
    B3CK, thanks much for pointing me to that article. that device will definitely be seeing installation in version 2 of this keyboard. But putting it in this one would be too much hassle (re-doing a ton of wiring, finding a place to put another switch). This also means that I will end up selling this keyboard sometime in the future (not short-term, though. Maybe around christmas, probably later)
  3. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    Nice, tho you may want to put some kind of cover on the bottom of the board, wouldnt want to touch that Hard Disk Controller by accident, now would you?
  4. udjamaflip
    udjamaflip -
    13 Aug 2005
    This keyboard is coming along pretty nicely :thumb: , i may have missed this being answered :blush: .... but how ARE you connecting it all to the PC as if ur doing it with 1 usb cable driver conflicts would be innevitable i think :confused: and wouldnt loadsa usb cables be a bit messy? if u made it all wireless that would be very impressive :)
  5. Jerm
    12 Aug 2005
    Signal comes from PC
    Goes to the USB 2.0 hub
    The hub has the hard drive on one port, the card reader on another port, and the keyboard on a third, and the fourth is open
    All 3 of those ports can be switched off to save power
    The keyboard has a 2-port hub built in
    One port goes to the serial->USB adapter for the LCD
    This port can be switched off
    The other port goes to the USB 1.1 hub
    The USB 1.1 hub has the wireless mouse receiver and 3 open ports
    There is a basic function diagram of it on page 1, post 19 (its a link, so you have to look closely)
    I have a question for you, though. How do you make a USB 2.0 hard drive wireless?
    Seriously, do they make wireless USB hubs that would rock my world!
    Only 2 external cables: USB to PC and power. All devices on this keyboard are in the keyboard. Inside, there are a lot of cables (see pictures), but the 2nd picture in my last post shows it with the metal on it that the keys sit on top of. The thing will be no taller, wider, or deeper than stock.
    As for driver conflicts, I have tested it without the LCD and mouse and everything ended up working.
    I will probably coat the underside of the HDD and W/less mouse with plexi and light it up. But I won’t get to that until I go to college.
  6. shomann
    shomann Minimodder
    5 Sep 2003
    Dude!
    The only thing that sucks about this mod is that you beat me to it! I need to get off my dead-ass and start modding stuff before all my ideas are trumped by someone else!
    I invisioned only a LCD screen, hub and maybe card reader.
    Good luck, looking forward to seeing this finished!
    Note: I realize there are tons of keyboard mods out there, but this is the most ambitious that I have seen.
  7. CollinstheClown
    CollinstheClown Hi
    30 Jul 2005
    Nah, sorry they don't make a wireless USB hub.... yet that is. They sure would come in handy!
    -CollinstheClown
  8. 7echMOm0dder
    7echMOm0dder What's a Dremel?
    18 Aug 2005
    Nice! I cant wait to see it finished!
    Did you ever think to put a wireless start button for your computer in it!??!?
    I think that would be awesome! I have heard ways to do it and am going to try iy out myself, but it envolves a doorbell! :thumb:
  9. shomann
    shomann Minimodder
    5 Sep 2003
    Why go wireless if you are already tethered to the CPU regardless? Just throw a vandel switch on the side and be done with it ;)
  10. Jerm
    12 Aug 2005
    Update 8/18
    8:00 PM Eastern US Time
    finished the top cover of the keyboard. The paint didn't come out great but hey, it's my first time and I've heard Krylon isn't good anyway. But i do like the way the switches and their USB ports came out. And for some reason I actually like the white on black. But thats probably just me, right? :p
    overall shot of it, minus the light tubes for the lock-keys (Includes frosted acrylic piece for HDD/Mouse activity lights)
    view of the rear left, close-up of the USB ports and some wiring
    close-up of just the switches how I'll see them
    more later tonight! (dont worry I wont make a separate post for it)
    10:30 PM Eastern US Time
    the only other thing I really accomplished tonight was making the light for the board. It is my first foray into heat-shrinking, and tomorrow morning I'm spray-painting it (priming it anyway). the switch that it uses is an on-off-on type switch, so i soldered it for a high-brightness setting and a low-brightness setting. The shroud over the LED's is actually a windows key from an old keyboard, and the inside will be lined with tin foil (or other, less wrinkly reflective metal) becuase as of right now all the light just gets soaked up by the shroud.
    light on keyboard
    closer shot of light, the cord on the back of the keyboard, to the right of the light, is the power cord (yes, both power and light are RCA
    Note the position of the rightmost switch in these next 3 pictures
    High-power
    Low-power
    Off
    lamp. It's removable for when I don't need it, and its backbone is 8 or 10-gauge wire so its stiff but also slightly flexible if I want to bend it. it will be geting a new paint job
    Hope you like the results of tonight, i know things are moving slow but I'm getting close to finishing.
    Thanks for your support so far!!! :thumb:
  11. GuardianStorm
    26 Apr 2005
    Hehe the lamp is a cool addition, is it USB powered too? :p
  12. Who_me_33
    Who_me_33 What's a Dremel?
    26 Oct 2004
    Its probably off the 5v that he's feeding to it. Because he has so much in the keyboard, he has to feed it extra power for it to work.
  13. Rekarp
    Rekarp What's a Dremel?
    7 Mar 2004
    in think a flux capacitor is a must :)
    but you better make sure you have sufficent power from your USB port to do it.
  14. Jerm
    12 Aug 2005
    sorry for the lack of posts recently. I have had a lot to do (getting ready for college, etc). I may get some work in this week, but i may not get any in for the next 2-3 weeks.
  15. wilkyboy
    wilkyboy What's a Dremel?
    20 Aug 2005
    i never was a fan of those lil flicky switches :p
