Linux Ubuntu + Azureus (headless/console) on startup
Discussion in 'Software' started by nry, 23 Jun 2008.
  1. nry
    nry Minimodder
    1 Nov 2006
    Setting up a file server which needs to run azureus, would use another torrent program if I could
    I don't want the gui to run on bootup which is easy enough.
    But I can't get azureus to load on startup with out causing problems.
    Tried following this: http://phillstechstuff.blogspot.com/2007/01/howto-get-azureus-to-start-at-boot-and.html
    But it just causes it to hang just before you enter your user name (console) so I have to press ctrl+alt+del and enter recovery mode to remove the script.
    Any idea's on whats stopping this from working?
    As if I load azureus in the console it works fine (although I cant get it to run in the background)
  2. Glider
    Glider /dev/null
    2 Aug 2005
    It should start right before you can enter your username, since you made an init script for it.
  3. nry
    nry Minimodder
    1 Nov 2006
    It should but something is causing a problem somewhere. I have left it for 10 mins at the screen before it allows you to enter the username and nothing.
    I think it might have something to do with the fact I can't run the azureus program in the background using something like
    java -jre /home/nick/azureus/Azureus2.jar --ui=console > /dev/null
    It just loads it then dosen't let me use any other commands than that of the azureus console.
