Linux Ubuntu boot problem
Discussion in 'Software' started by Carbonphiber, 24 Jul 2005.
  1. Carbonphiber
    Carbonphiber What's a Dremel?
    26 Mar 2005
    I'll start by saying I'm very new to Linux. Anyways, I when I first installed Ubuntu I only had a DVD drive connected. Everything was fine until I connected my CD burner. Now it hangs as it's "Starting Ubuntu". It only hangs when I have both drives connected. If I only connect one, it's fine. What do I need to do to make it work with both?
  2. macdude425
    macdude425 What's a Dremel?
    13 Mar 2005
    Does it produce an error message? Tried editing /etc/fstab?
  3. Carbonphiber
    26 Mar 2005
    There aren't any error messages. It just hangs while it says "Starting Ubuntu". I haven't been able to get past that. I haven't tried editing /etc/fstab. What exactly would I do?
  4. trigger
    trigger Procrastinator
    22 Mar 2004
    Are you dual booting? If so does Windows boot OK?
  5. macdude425
    13 Mar 2005
  6. Carbonphiber
    26 Mar 2005
    Nope, I'm not dual booting. I only have Ubuntu on the thing. Thanks for the guide, I'll take a look through that.
  7. trigger
    22 Mar 2004
    In that case are you sure your jumpers are set correctly on the drives? If they are, any idea what boot options you're using?
    edit: Ooo, just had a thought: maybe the second drive is taking the device number of the boot drive. So where before the HD may have been /dev/hdb, now the second CD drive is taking /dev/hdb, and the HD is now /dev/hdc, in which case you may just need to edit your bootloader config file. That's /etc/lilo.conf if you are on lilo, I'm not sure about grub though.
  8. Carbonphiber
    26 Mar 2005
    If by the jumpers on the drives you mean master/slave/cable select, then both optical drives are set as cable select. It doesn't seem to matter which drive is master and slave as I've switched the cable and gotten the same result. The bios does recognize each drive separately and whatnot. I haven't changed any boot options.
    In the case of editing the bootloader config file, what exactly would I do? Sorry, I'm new to Linux as a whole. Any more details regarding that would be greatly appreciated.
  9. trigger
    22 Mar 2004
    I've just checked and Ubuntu uses Grub, which is a black art to me. Try telling to guys at the Ubuntu forums, or even on Ubuntu's IRC about the problem, and they should be able to help!
  10. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    I had trouble with two optical drives when I first installed Ubuntu. They were both on cable select which shouldn't have been a problem, but it seems Ubuntu is sensitive to that sort of thing...
    Change the jumpers so that they match the drive's Master/Slave positions on the cable, and then try to boot Ubuntu again. That solved my problems with dual optical drives.
