Linux Ubuntu - isn't it wonderful!
Discussion in 'Software' started by Zinfandel, 17 Aug 2010.
  1. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    I'd just like to say that so far, Ubuntu is possibly the most amazing piece of software I've ever, ever seen.
    It's just... wonderful.
    Even small things like how the media player stays in full screen on a play list.
    And I'm searching through all the apps, there is a whole SECTION dedicated to chemistry based apps, and biology, and engineering and EVERYTHING.
    I'm a bit excited, sorry. But this genuinely is awesome.
    Although the close/minimise buttons are on the left like a mac, but I'll get used to it.
    Thank you to Glider for his epic guide
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Latest PC Pro has a good article comparing Ubuntu (which is one of the cover disc's) and Windows 7. Well worth a read.
  3. simonw
    simonw What's a Dremel?
    24 Jun 2009
    Welcome to the world of Ubuntu, I've been using it since v8.10. For beginners, there is a very good manual that is recommended.
  4. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    It's pretty amazing considering it's free
    My mom even likes it :)
  5. Fingers66
    30 Apr 2010
    ^ THIS is what will make it even more popular, not the geek vote.
  6. aradreth
    aradreth What's a Dremel?
    20 Aug 2009
    If you want you can change the position of the buttons. I'm not sure how as I dislike gnome and as such don't use it but I'm sure there will be someone along shortly with the info.
  7. Coltch
    Coltch Minimodder
    3 Jul 2009
    I tried Ubuntu 10.04 for a couple of weeks but went back to Debian Lenny on my main machine.
    Using Fedora 13 on my lappy and prefer it over Ubuntu (although after using Debian it's a bit different).
  8. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    I'll try out Kubuntu which I believe uses a different "window" system. I'm new to it all so I'm sure I'll get there.
    The "Science and Engineering" bit of the Software Centre is genuinely amazing.
  9. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    I'll pick a copy up when I'm next at le shops, cheers for the heads up.
    Thanks very much. I shall search away :D.
  10. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Ubuntu uses Gnome, Kubuntu uses KDE.
    However, KDE is "simply" an application which sits on top of a Linux distro.
    You can just use Synaptic to install KDE, and have that start instead of Gnome, to try it.
    From the command line:
    sudo apt-get install kubuntu-desktop
    If you decide you prefer Gnome:
    sudo apt-get remove kubuntu-desktop
    More here: http://www.debianadmin.com/install-kde-desktop-in-ubuntu.html
  11. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Thanks for that. I've read a few bits about these command line things. Hopefully there will be more in this manual I'm reading but I don't know anything about them yet.
    And I started using PCs when they ran on DOS :blush:
    In other news, I downloaded a new theme that has the minimise/close options on the right hand side... Awesome.
  12. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    One of the reasons Microsoft software is so successful is not because it's good (it isn't) but because they have excellent installation routines - you stick the disk in, answer a few questions, and just let it install and it just works.
    Up until recently you couldn't say that about Linux/Ubuntu but now you finally can. And it'free!
  13. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    I use Mint (based on Ubuntu) on a virtual host server and a few laptops I have at home. I love it, although Flash based websites can run badly and some things still have to resort to terminal commands.
  14. Dark Matter
    Dark Matter Minimodder
    12 Mar 2010
    Is this the best flavour of Linux for a novice user, and what are the HW requirements?
  15. ataraxis84
    ataraxis84 What's a Dremel?
    6 Oct 2009
    From personal experience, yes.
    It has lots of features aimed at windows users, and a really good forum for getting answers to problems.
    I remember running it on a whitebox laptop from a live CD, and it managed to get all the hardware working straight away without having to install drivers etc, where it took me the best part of a day to get the windows drivers for it :D
  16. Dark Matter
    12 Mar 2010
    Thanks for that :thumb:
  17. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Sys req are tiny. 700mhz PSU (Which I read is quite high for some Linux stuff but still very low) 256 ram, 3gb HD.
  18. gymman39
    gymman39 What's a Dremel?
    29 Jun 2010
    might give this a try in the next week or 2
  19. Dark Matter
    12 Mar 2010
    Excellent :thumb:
  20. Dark Matter
    12 Mar 2010
    Same here I have an old Athlon 1200 machine with 40 &80GB Hdds one drive with XP so may have a go at installing Ubuntu on the second drive. The machine has 1GB ram so this should be fine! :)
