Linux Ubuntu Running Fluxbox Help Needed!
Discussion in 'Software' started by 123mccann, 30 Dec 2007.
  1. 123mccann
    123mccann What's a Dremel?
    16 Dec 2007
    I am using the ubuntu 7.10 Distro, and today I installed Fluxbox as a WM, and i am encountering a few awkward problems:
    1. How can i change the screen resolution to 1680 x 1020
    2. How do i change the size of the text in the right-click menu and firefox, as they are so small it becomes a struggle to read.
    3. Is it possible to change the wallpaper, as the blue gets quite BORING!! :duh:
    4. How do i browse my files and folders in the GUI.
    5. Can I use different styles from the ones available in the menu
    Thanks.
  2. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    1. With the xorg.conf file
    2. edit your fluxbox config file
    3. edit your fluxbox config file
    4. nautilus or konqueror
    5. yes, documentation tells you where to put the styles and you can change it through the menu. Alternately, you can make your own styles.
  3. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    run
    Code:
    sudo dpkg-reconfigure xserver-xorg
    and select your resolution, its one of the last questions.
  4. 123mccann
    16 Dec 2007
    The fonts are still microscopic and un-readable, how do i edit the fluxbox config file?
    Also, when i try to open nautilus, it loads the gnome desktop background and icons, which cannot be used. Then the right-click menu can no longer be used.
  5. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    To browse file use:
    Code:
    nautilus --no-desktop
    To change wallpaper:
    Code:
    Than add:
    Code:
    fbsetgb -l
    to your ~/.fluxbox/startup file.
    Also, read man fluxbox.
  6. 123mccann
    16 Dec 2007
    I don't appear to have that? I can only find /usr/share/fluxbox
    Can't find any other folders which relate to fluxbox :rolleyes:
  7. DougEdey
    5 Jul 2005
    you won't be able to ls it straight away. type cd ~/.fluxbox and you'll get into the directory
  8. Fophillips
    9 Oct 2006
    It may not exist yet. Just mkdir ~/.fluxbox
  9. 123mccann
    16 Dec 2007
    Yer I've found it, strangely enough I opened the "startup" file, without any adjustments and font size has gone perfect. :D
