Scratch Build – In Progress UDesk [Airtight, Very low noise PC built in Desk] Updated 3th July 2014
Discussion in 'Project Logs' started by uberniner, 1 May 2014.
  1. uberniner
    uberniner What's a Dremel?
    29 Apr 2014
    Your comment is completely valid, the light distraction was considered and is also the reason why the components are located off center, quite a lot to the right. In case this wouldnt be enough, there is a remote control for color, intensity and generally the state of the illumination. So if it would bother me, I would just turn it down or off.
  2. hoochy
    hoochy Need moar cooling
    16 May 2012
    Thanks! Even more exciting if you constructed it yourself as part of the project also - certainly looking forward to seeing this progressing :)
  3. uberniner
    29 Apr 2014
    You can take a look at some screen/lamp holder 3D models. ;)
  4. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    That is so cool!
    Can you post a close up screenshot of the joints?
  5. uberniner
    29 Apr 2014
    Nah, I dont have any screenshots.
    What I do have is the real thing :D
    Ocelot likes this.
  6. uberniner
    29 Apr 2014
    Time to move forward
    And to the case itself
    Testing the extension mechanism
  7. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    That is amazing! I love functional designs.
    I am curious to know what tools you use for bending. Could we get some shots of your workshop?
    Your Screen mount is amazing too. It reminds me of how some desk lamps are deigned.
  8. morgansk
    morgansk I've got wood
    12 Jan 2013
    Epic lifting mechanism, love it! :D
  9. uberniner
    29 Apr 2014
    Painting stuff! Cheapass black matte paint looks kinda good.
  10. Z0DIAX
    Z0DIAX bending alloys
    26 Jul 2013
    wow, you got serious metal work skills, and an epic design...
    subbed
  11. uberniner
    29 Apr 2014
    thanks!
  12. uberniner
    29 Apr 2014
  13. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Is it just me or is anyone else thinking robot wars?
  14. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I usually don't really pay attention to desk builds as so many of them are just another "stuff a PC in a desk" projects, but this has got some interesting ideas. Your metalwork looks great. The lifting mechanism is really ingenious.
  15. jimbaw
    jimbaw What's a Dremel?
    8 May 2014
    wow. I was happy when it only took me an hour to build my daughter's flat packed swing (only swore 52 times and threatened the screw driver a couple hundred of times). I now want to cry.
    looks amazing mate!
  16. chilliewillie
    chilliewillie What's a Dremel?
    14 Apr 2014
    with what do you bend?
  17. uberniner
    29 Apr 2014
    Sorry for the delay. I use professional bending machine, it was old and cheap, but works perfectly especially with thin AL or steel. 3mm AL requires a lot of force.
  18. uberniner
    29 Apr 2014
    Time for an update! Things are coming together.
  19. NoRmZiDiUs_669
    NoRmZiDiUs_669 What's a Dremel?
    22 May 2014
    This looks absolutely amazing!! subbed
  20. trintragular
    trintragular What's a Dremel?
    29 Oct 2012
    Thanks for the recent update - I'm doing my Homer impression from the first page right now!
