Windows UFO Alien Invasion - Free game, Xcom fans will like
Discussion in 'Gaming' started by Guest-16, 22 Jun 2008.
  1. Guest-16
    Guest-16 Guest
    http://ufoai.sourceforge.net/
    I thank Gareth from Corsair (UK) for hooking me up with this. I like playing it, it does drive the same gurgling innards that made Xcom 2: TFTD so compelling (although it's more like Xcom 1) but it's nowhere near as scary to play as #2.
    There is multiplayer too, but I haven't tried it.
    Graphics are not bad, but shitty Intel graphics just don't cut it on this laptop unfortunately because I get 10fps at 1024x768, "Normal" settings.
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    Sounds good, i miss not been able to play Xcom: TFTD as it wont work in vista
  3. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
    That's so strange. I was actually looking at playing this as well today.
  4. m0o0oeh
    m0o0oeh Well-Known Member
    20 Dec 2006
    Won't install for me for some reason
    Joe
    ::EDIT:: ah... it only downloaded 1.something meg of the file. Lulz.
  5. Guest-16
    Guest-16 Guest
    Duuuuuuuuuude we should multiplay :naughty: There's somethings/tactics that need discussion.
  6. CardJoe
    3 Apr 2007
    Sure, it'll fill the time until Left4Dead - Then I'm going to be team captain. Of the awesomeness.
  7. ChromeX
    ChromeX Active Member
    12 Aug 2004
    I've not been able to play it on my crappy monitor, for some reason it doesnt like 320x240 or whatever it is. And I cant seem to force it into 640x480! There was always aftershock but I find it massively poo!
  8. Lemmingzappa
    Lemmingzappa New Member
    8 Nov 2004
    Thanks for this, i'll give it a try later.
    Huge fan of the Xcom/Ufo Series !
  9. teamtd11
    31 Aug 2005
    My monitor showed on the infomation that it was running at 1920x1200, though you could see the res was tiny, must of been its way of getting it to work
  10. ChromeX
    12 Aug 2004
    Ah, that would make sense. My monitor is off a mate cos mines broke, but its really really crap the max resolution is 1024x768, when I tried to run the xcom fix thing all I got was the out of range message.
