Modding UFO Circuit PCB - Updated! ZAP I need your comments!
Discussion in 'Modding' started by bsodmike, 16 Aug 2003.
  1. bsodmike
    bsodmike Banned
    11 Oct 2002
    Really quite simple. I dont have teh equipment to etch the pcb (using Zaps guides) so I'm getting custompcb.com to do it for me, wont be more than $20+ shipping for 2boards (I got another case I can use this with).
    100000mcds forward from the rear to the front of the case, 20000 back wards on the edges and 10000 to the left/right of the case.
    Hoping to embed this into a 1cm sheet of plexi.
    Did the board in Eagle this time round. Some people have advised me to use 50ohm resistors per led as the leds are as follows:
    fv= 2.5v, current: 30mA so I'll use 75ohm resistors.
    Code:
    Order Code PF07H: High Efficiency Red
    Toshiba description: TLSH180P
    Forward voltage max. at IF=20mA: 2.5V
    Forward current max.: 50mA
    Reverse voltage max.: 4V
    Wavelength @ peak: 623nm
    Power dissipation PT: 125mW
    Light output min.@ 20mA: 2720mcd
    Light output typ.@ 20mA: 10000mcd
    Let me know if there are any errors!
    Thanks, Mike
  2. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    eh... WOW! you know.. 140000mcd is BRIGHT!
    i have ONE led on 8000mcd connected to the USB port (made last night... it was dark...)
    I lighted uoy the window.. and i could calerarly see the light on the lawn.. (i'm at 2nd floor)
  3. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    Yeah... That's bright... Well I'm sure there isn't a law about creating devices brighter than the sun, but I'm sure there will be...
  4. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
    sweet stuff...got to call custompcb.com :)
  5. bsodmike
    bsodmike Banned
    11 Oct 2002
    CustomPCB are very good, Gary Cho is the owner and is very quick, courtious and basically does a very good job!
  6. bsodmike
    bsodmike Banned
    11 Oct 2002
    <<<<<<<<<<<<<[Part2]>>>>>>>>>>>>>>
    (thanks to Hazer, Aegis`)
    Vcc:5V, Vled: 2.1V
    Current:
    Iled = (5-2.1)/150 = 0.019A
    Ir=Iled=0.019A, therefore total current= 0.019*14 = 0.266mA
    Power:
    Power per led (Pled) = 2.1*0.019 = 0.0399W
    Power per resistor (Pr) = 2.9*0.019 = 0.0551W
    ***check: Pt=Pr+Pled=Vcc*I=5*0.019=0.095W
    Total Power: IV = (0.019*5)*14 = 1.33W
  7. japala
    japala What's a Dremel?
    8 Dec 2001
    You are missing one wire from the led on the lower left hand corner of the board/image.
  8. bsodmike
    bsodmike Banned
    11 Oct 2002
    Thanks, did not see that!
