Apple uh-oh.. my Macbook just random shudown'd!
Discussion in 'Software' started by J-Pepper, 31 Jul 2006.
  1. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    4 times in a row!!! it's not a software issue!!
    Using it last night (it first started last night) whilst plugged in. Shutdown.
    Now this morning, on battery power (~1:24mins left) it shutdown.
    But even worst is that when I go to switch it back on, it keep shutting down again within a second.. it did that four times in a row until I left it for a minute and turned it on again. Now i'm writing this.
  2. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    hmm
    reset firmware/pram/PMU?
  3. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Try a PMU reset, this is the Power Management Unit. If not, faulty battery or connections, or something else to do with that. Is it overheating? The mooing fom MB's and MBP's are from a central fan near the monitor, that turns on and off every second.
  4. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    just been on the Apple Discussion forums, apparently, i'm not the only one with this issue.
    It seems pretty widespread with quite a few people experience the same random shutdown of their machines.
    I think it's time to consider an Apple Care upgrade next time I fly to HK.
  5. Atomsk
    Atomsk What's a Dremel?
    13 Mar 2004
    I know with my mbp after I bought new third party memory i started having that happen but that is a fairly common thing with most types of ram and the intel macs.
  6. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    yeah, but it have it run perfectly fine for 2 months before showing a problem?
  7. simon_C
    simon_C Minimodder
    13 Nov 2005
    check to make sure the ram is seated correctly. ive had this happen on a desktop with loose ram.
  8. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Put your os X disc in it while booting and hold -see in your manual- button in.
    There should be a bunch of tests on there, diagnosing etc..
    L
  9. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    well.. it's happened a fair few times, so now Apple have sent a courier around for tomorrow and that they'll get it fixed straight away as they said it's obviously a hardware issue and they're sorry for any inconvenience caused.
    They are also going to do something about my moo-ing and to change the palm rests if need be.
  10. Fod
    26 Aug 2004
    what's wrong with the palm rests? discolouring?
  11. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    not much on mine, but I said it anyway because it's a documented issue, so they'll take a look and if there are signs that it's discolouring, they change it I guess.
    Apple are usually pretty good when it comes to fixing things.. their stuff breaks down just as much as anything else out there (bar toshibas in my experience) but when it comes to fixing issues, they are the best in my experience.
