Modding UK: Spray Cans
Discussion in 'Modding' started by cool_dude, 16 Jul 2006.
  1. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    Hey...
    Searched the forum and cant find a thread with what im about to ask....
    does anyone here know a cheap place for spray cans (except for halfords) as im going to be practice painting, and i want some cheap spray paint to practise with, i dont feel like spraying a £5 can to practise with :p
    Even if its just a place with - black,primer,laquer that'll be fine.
    Thanks,
    c_d
  2. Boswell
    Boswell Minimodder
    23 May 2005
    Have you tried ebay there might be a bulk load or something that would go for next to nothing - most likely.
  3. cool_dude
    26 Aug 2004
    Yeh, i dont want a job lot, just somewhere like sub <£3 a can.
    Its just for practise, so dont want the cans to be expensive.
    Black | Primer | Clear Laquer
    Are what im looking for :)
  4. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
  5. cool_dude
    26 Aug 2004
  6. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Wilkinsons are pretty cheap but dont have an enormous collection.
  7. cool_dude
    26 Aug 2004
    Okay thanks guys, after searching for about 2-3 hours last night, it ends up halfords being cheaper with their 3 for 2 deal. Reason being, most online stores have cheap cans, but the delivery is high going above what halfords would actually cost.
    hopefully this thread wont be a waste of time, and will help and uk'er searching for spray paint that halfords is the cheapest store for spray paint.
  8. frodo
    frodo What's a Dremel?
    1 Nov 2003
    but it REALLY isnt
    just because theyre 3 for 2 deal is on, you still end up spending alot to get a little
    cheapest PLACE in the UK to get spraypaint is trago mills, black/clear laquer/primer @ 1.35 for a large can, compared to the £4+ for that of halfrauds... plus i dislike halfords paint
    only time i reccomend buying paint from halfords is if you want to a coloured spray job
    the downside of trago is that they dont offer many colours, some places only do black/primer/laquer.
  9. cool_dude
    26 Aug 2004
    any where is that exactly? If you can point me to the online store where i can order from then that will be great, because im only after - black,primer,laquer.
    £1.35 for a can is a great price to practise with. :)
  10. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    info on trago mills site: http://www.trago.co.uk
    you have to go there...no online shopping :p great place though, i have been to the Newton Abbot one :)
  11. cool_dude
    26 Aug 2004
    quite a way for me, should have stated i want well known/big stores if they dont do online shopping.
  12. atanum141
    22 Jul 2004
    Im sticking my hand up for Halfords, I know it aint cheap but Ive bought cheap paint before for £1 a can from Poundland and it simply isnt up to the job.
    The paint runs and the nozzle is extremely bad and leads to "splatter" effect which intails a crap paint job.
    The halfords stuff covers evenly has a good nozzle and the finish of the paint is very good for bare Alu case. Also Halfords sell Plasti Kote paints which are well know to be verry good.
  13. merlin 65
    merlin 65 What's a Dremel?
    13 May 2006
    most small automotive spares shops have a bargain bucket with odd spray cans in em , and also the bargain buckets in b & q have em too if its only to practice im assuming you dont mind the colour
  14. peteone
    peteone Minimodder
    5 Jun 2002
    I say halfords too. I once had to paint the centre caps on my RS4 Alloys and was quite supprised to see that the paint actualy stayed on for a couple of thousand miles and numerous jet washes, not bad imho. Tis quite expensive though.
  15. Callum
    Callum What's a Dremel?
    4 Apr 2006
    Paint is so expensive there! It's about 60p here!
    *does not look forward to moving to a Western country*
  16. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Have you tried asking around with your mates?
    Chances are someone you know has a few cans cluttering up their garage, I know I have :)
  17. Agent_M
    Agent_M Minimodder
    4 Feb 2005
    theres a shop that sells spay cans tailored for grafiti in leyton, or atleast they used to when i worked there, i think its about £3 a can but top quality stuff and alot of colours.
    dont know if the paint they sell is diffrent to the paint you get in places like halfords but i think it is, anyway the shop is skaters paradise on leyton highroad
  18. Bentos
    Bentos What's a Dremel?
    12 Feb 2002
    for a massive selection of colors (all you could want) graff paint is the way to go; durability wise, well it sticks to walls for time (until it gets buffed by the council)
    anyways:
    google: monstercolors, valley of chrome, the layup
    all pretty good, bout £2.50 a can, delivery a bit of a pain
  19. cool_dude
    26 Aug 2004
    Nah my mates wouldnt have any spray cans laying about :/
    Yeh delivery is the main price killer, after delivery it makes halfords cheaper by a few quid.
    Every time I go into bnq they never have anything like that, must be my b&q because alot of people reccomend bnq for quite alot of stuff (acrylic etc) and mine is either a total rip off or doesnt have it...
    Guess i'll have to practise with the halfords paint then, now i just gotta look for a case to do it on :D
  20. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Wilco do Plasticote and I bet they're cheaper than Halfords.
