Hey Guys Anyone know of any uk-based shops that do 15" touch screen conversion kits? I've found a few on eBay but they're from Hong Kong - ideally wanted something UK based. Also anyone had any experience with converting their standard monitor to touch screen? I don't mind the ones that need the monitor to be opened, the 'clip on' ones are probably more expensive. Thanks peeps
So you want to make your desktop computer monitor a touch screen? firstly why and secondly large touchscreens are very expensive, you're better off getting a 7" touch screen to use like a design tablet(in terms of positioning).
Oh cool i thought you meant you wanted it as a main monitor as well...that would be crazy. Good luck with it though .
