Case Mod - In Progress Un[titled] Master[piece] - completed more or less
Discussion in 'Project Logs' started by sethnmalice, 1 Feb 2008.
  1. skullen
    skullen Minimodder
    31 Oct 2007
    Nice one seth :thumb: like those flames :D
  2. sethnmalice
    sethnmalice What's a Dremel?
    21 Jul 2007
    UPDATE 11th Feb 2008
    Finished one of the feature side panels today, 2 days of filing and cutting and hands cramping...
    This took 4 hours....
    Another 5 hours later....my hands were taking its toll.....and filing takes forever....even on alu , 2mm
    Completed the last part this morning, quite happy with the end result but its not quite finished, still had to de bur the edges, both sides, and along the way a few scraps and errors, so im hoping that the sanding tomorrow can fix a few of my stuff ups before I polish it.
    Finished panel...
    Began work on the acrylic backing, I much prefer working with acrylic...
    A few hours later and I'm done, so what i did here was cut it out with dremel bit used for high speed cutting then ised a metal file and some jewelers files, but gave up in the end due to hand and finger cramps....went to the dremel tool box and picked out a metal sanding bit and really went to town on the acrylic to get it the way I wanted to...net result ^^...
    Combine the two pieces and it dosnt look half bad, but once the protective paper is removed and the red is showing it should look great.
    Still to do, flame paint the mesh backing.
  3. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    Nice details ! .. nice nice nice
  4. fflow
    fflow What's a Dremel?
    8 Dec 2007
    Realy nice. I like the mixing of styles like the flames and the more modern shapes. Cant put my finger on it but I really like it. Besides all the nice shapes the work you put in is a lot :thumb:
  5. brinkz0r
    brinkz0r What's a Dremel?
    15 Dec 2006
    You really know how to work for a long time straight, wish I could do that :worried: It's becoming really nice, so keep going :)
  6. DragonONE
    DragonONE What's a Dremel?
    27 Jun 2007
    Awesome....
  7. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    QTF.......................
    I love those flames :thumb:
    Alan
  8. sethnmalice
    21 Jul 2007
    @ zwiks, cheers :)
    @wolff2, thnx :) just trying new things with old things....
    @brinkz0r, Thnx :), I love modding, but it does take its toll, dosnt help the arthritis....
    @DragonONE, Thnx :)
    @theAlien, Cheers :)
  9. sethnmalice
    21 Jul 2007
    UPDATE 14th Feb 2008
    Its been a few days, I'm still recovering from the filing, but I wasnt going to let that stop me, just took it a bit slower this time round.
    Onto the other side panel, it too was going to get the flame treatment, but I didnt want it to look exactly the same as the other side, but certainly was going to use the same elements...
    So I cut out my side panel piece...
    But instead of cutting out the whole thing, I decided to only cut out the little bits (highlight pieces), this is my foundation, there will still be an acrylic piece backing it... (pay attention to the gaps)
    I cut out an acrylic flame piece and tried my hardest to get it smooth and close to concept design as i could (still needs to be sanded and edges polished)
    Lets add the two together...
    Like so....Its a nice contrast and keeps the theme flowing...
    And I decided this a while ago, that I was also going to use the flame design for the front of the case, this is the 120mm flame grill cover, yes it exceeds 120 mm, but thats the point...
    Still needs to be filed sanded and polished, polishing will be one of the last things I do as its the most time consuming thing everrrr :)
    I'm still unsure as to what I'm doing with the front panel , which is why you havnt seen it yet, but when things become more clear in my head about what direction im going to take on it , ill post some more stuff, as I wasnt completely happy with the original concept designs of it, I feel its missing something, so I hope something comes to me soon.
    Seth
  10. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    NICE .. uhh i realy like the sharp edges ! . omfg it looks nice .. good work.. keep it up comming :D
  11. G0RD0N FAN
    G0RD0N FAN Jeff Gordon #24
    16 Jan 2008
    You do some great work! Keep it up I cant wait to see it finished!
  12. Cheapskate
    13 May 2007
    Awesome work.:D
    I have to tell you- buying a scroll saw was the best thing I've done in years. It's saved me a lot of time and pain, and I don't use it nearly as much as you would.
  13. Sleepstreamer
    Sleepstreamer I modded christmas!
    23 Jul 2006
    I SO enjoyed your previous project Seth, and I'm eager to see this one progress too. Now get out of bed and keep modding! :lol:
  14. nickhelton
    nickhelton What's a Dremel?
    13 Feb 2008
    what are you using to cut out the flames?? it looks really clean
  15. sethnmalice
    21 Jul 2007
    @ zwiks, thnx :)
    @ G0RD0N FAN, thnx :)
    @ Cheapskate, thnx :), I have one in hiding I just cant use it, due to work area limitations, but once the shed is built I'm throwing the nibbler away for good. My hands have had enough.
    @ Sleepstreamer, thnx:), nice to have someone of ur modding caliber visit my worklog :), Progress Updates arent going to be as full on as F.N were, it nearly wiped me out, going to take my time on this one :)
    @ nickhelton, On the ALU flames, I use a nibbler to cut and 4 various sized metal files, on the Acrylic I use a dremel - Alu cutting bit to cut shape out, file edges down, then I use a metal polishing bit to get it all even at 37.000 rpm, takes a few hours but its worth it.
  16. sethnmalice
    21 Jul 2007
    UPDATE 16th Feb 2008
    Progress is going pretty good, although I hit a snag or two along the way and had to re-model a few ideas, but other than that alls going well.
    This was the initial plan, and its somewhat changed....keeping the flames though :)
    I dont know why I broke the acrylic up into 4 pieces, just seemed the right thing to do at the time, but I changed that and decided to go with this...
    1 nice huge piece all blood red acrylic...
    Add side panel design from 2mm alu
    Add blood red acrylic flames...
    Add 3 flame pieces...
    To give you a more 3D presence...
    Im quite happy with it, Its begining to look how I first dreamed of it in my sleep, and Im continuing with this throughout the whole case, just an immense mass of flamming, this is the right side panel, still have to do the left and redo the top and then finally move onto the front and then do something with the inside of the case as its 100% steel, make it lighter by removing some steel etc etc.
    Note: There are still some rough spots around certain flames as I'm exhausted from a long day of extreme filing, roughly 7 hours of filing, but its starting to come together now, and then ill be able to move onto the polishing...
    Seth
  17. zwiks
    zwiks My avatar: :D
    2 Jan 2008
    as i said before.. NICE :D
  18. sethnmalice
    21 Jul 2007
    UPDATE 22nd Feb 2008
    Production has been slow but consistant, I have finished both of the side panels (at least the construction side of it), a couple of changes took place...
    The right side panel (motherboard tray side) the red acrylic pieces were removed and replaces with a full sized piece, and I may also be doing this for the left side panel (still unsure).
    All the aluminium pieces have been cut out, filed, and sanded and polished, this is phase 1, there are going to be three phases, and with each phase I'm going to sand and polish and sand and polish and sand and final polish, and I hope to gain the advantage of completely removing the streak marks that plague each piece.
    Close Up
    Close Up
    Close Up
    Six pieces (only 3 shown), each of them were sanded back with grit 1000 (dry) then 1000 grit (wet), left in the sun to dry and to allow the alu panel pieces to heat up.
    Here you can see the difference between polished and not polished.
    All pieces polished, the reason I allowed the panels to heat up, is because it makes hand polishing alot easier, less rub time over all per piece, rather than start with a cold panel piece and rub to heat it up I allowed heat first then polished it up, not bad for phase 1.
    Opposite panel not polished...
    And now polished, streak marks are obvious and something I will fix in the next phase.
    Both panels are completed, but now the time consuming work begins, each acrylic piece will be sanded 1000 to 2000 grit dry then wet, then the edges will be polished, not all edges will be polished due to inaccessability, those will probably get a light sand.
    Center pieces are done on 2mm and smaller pieces are 1.5 mm and the acrylic is 3mm (incase you were wondering)
    Now onto phase 2....
    Seth
  19. craig_h
    craig_h What's a Dremel?
    29 Jan 2008
    What nibbler do you use? Hand or electric.
  20. sethnmalice
    21 Jul 2007
    @ craig h, hand nibbler
