Other Unable to find network card
Discussion in 'Tech Support' started by StevieG5, 22 Sep 2009.
  1. StevieG5
    StevieG5 Why is nothing ever straightforward
    2 Feb 2008
    Hi, I am reinstalling the operating system for a friend and have loaded Windows XP Home with SP2. However, there are no network connections showing and when I scan for new hardware it says it can't find the network card. The guy is on holiday and assures me has no CD for the PC which I thought may load the network connections. Any ideas please. Thank you.
  2. Pady
    Pady What's a Dremel?
    12 Nov 2001
    hi stevieg5, can you confirm the model of the motherboard or make and model if a prebuilt pc?
    Pookeyhead likes this.
  3. StevieG5
    2 Feb 2008
    Hi Pady, yes I'll do that as soon as I get home. Thank you.
  4. StevieG5
    2 Feb 2008
    Hi,
    Its a prebuilt Packard Bell PC with the following details.
    Model/Type Ref: CHo-Bo8
    M8 Model: Bo8 AD0086
    P/N: PB49304701
    Model Name: ISTART 1360
    Mobo: ASUS M2NS-NVM/S
    Hope this helps
  5. tommyboy
    tommyboy What's a Dremel?
    23 Sep 2009
    Is it a built in Nic card? If not reseed it. Worst case just install a new nic card.
  6. StevieG5
    2 Feb 2008
    Hi, its an onboard NIC. The problem is there is no Network Adapter showing in Device Manager. Would installing a devoted NIC sort this please?
  7. B3CK
    B3CK Minimodder
    14 Jun 2004
    Yes, you should be able install a pci network card.
  8. edz
    edz What's a Dremel?
    18 Aug 2003
    Try the Asus website for network drivers for the motherboard.
  9. StevieG5
    2 Feb 2008
    Got the drivers now from Asus and the Packard Bell sites. Thanks for your help guys.
