Unable to get work units
Discussion in 'bit-tech Folding Team' started by ArthurBuse, 6 Jun 2016.
  1. ArthurBuse
    ArthurBuse CustomBitChimps member
    26 Apr 2009
    For the past 6 days I have been unable to get work units.
    I am using client 7.4.4 on Linux Mint. CPU is an old AMD 8-core. I get lots of log messages like this:
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Are you running a GPU as well, so that you have the number of CPUs set to 7?
    Prime numbers, and multiples of large primes, are an issue, and 7 has been 'banned'. Try setting the number of CPUs to 6.
    If this is not the case, and you have it set to 8, then I'd delete the slot, save and then re-add a slot.
  3. ArthurBuse
    26 Apr 2009
    Thanks, that fixed it.
    FAH was folding on 7 cores, leaving one for me as it was set to Medium use. FAH refuses to use my ancient GPU but it is good enough for me as I do not play games. I have now configured it to use 6 cores.
  4. Bogdanovki
    Bogdanovki New Member
    10 Sep 2016
    I have no trouble getting work units, but I now have 4 work units that could not be sent to the server. 1 Per GPU... . Anyone got any ideas?
  5. houch
    houch Member
    26 Mar 2009
    im having the same trouble BUT im a novice at this so would like an idiots way to change it, i have a alienware 17 r4 , the gpu is folding but the cpu will not find a work unit
