Motors underpowering sub?
Discussion in 'General' started by bee2643, 5 May 2005.
  1. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    i have a clarion 400watt amp with 15" 600watt sub (clarion) and when i play my music loud it sounds like its almost blown, its relatively new, and when i turn it back just a few notches it sounds better, but then its not as loud as i prefer to listen to it at.
    is it possible that my sub just needs more watts to make it sound good?
    is there a way to fix this without buying a whole new 600watt amp?
  2. MaximumShow
    MaximumShow Minimodder
    20 Jan 2003
    what you are hearing is one of 2 things.
    1)the sub is bottoming out. What type of enclosure is the sub in?
    2)you are clipping the amp
    both of these can have a horrible effect on the sub, and can destroy it quite easily. I would say that more than likely you are clipping the amp, drawing more power from it than it can put out. This will cause distortion (what you are hearing) and can damage the voice coil in the sub. From my experiences, it is better to have too much power than too little.
    Exactly what amp and sub do you have?
  3. shroom
    shroom What's a Dremel?
    6 Aug 2003
    We could also use the RMS input of the sub and output of the amp, and whether or not its bridged, etc etc. Basically the details of the whole setup.
  4. bee2643
    7 Mar 2002
    not sure on the details of the equipment. its in a 15" Ralphs Radio enclosure, i am bridging it.
  5. MaximumShow
    20 Jan 2003
    well in order to help you we'd need the specs of your equipment. But I am quite sure you are clipping the amp.
  6. bee2643
    7 Mar 2002
    is there a way to fix this other than buying a new amp?
    or lowering the volume :(
  7. shroom
    6 Aug 2003
    To find the info on the amp: turn it over, should be a model number on the bottom.
    To find the details on the sub: Unscrew it from the box, look at the back, should also be a model number there.
  8. bee2643
    7 Mar 2002
  9. shroom
    6 Aug 2003
    The link for the amp you provided us is nothing but a page with general info about the manufacturer.
    The sub, however, is 600 watts MAX. I was unable to find more info on the sub, so I'm going to assume that it is 300 watts RMS (its typical for the rms of a sub to be half of its peak). Incase you are unaware, the rms is the amount of power to be pushed through a speaker at any given time, while the peak is something that really will never be reached in a typical setup.
    You say you have a 400 watt amp. So We're going to assume thats 400 watts across two channels. Bridged, your sending 400 wats to your sub, if its 400 across 4 channels, then your sending 200 to your sub. I think. This is where my knowledge of car audio gets fuzzy.
    Long story short: Your sub is only 300 watts and your amp is overpowering it, as mentioned before. Your solution, is to not bridge it ,or buy a smaller amp, or bigger sub. I would recommend a bigger, sub, and I'm hoping that you didnt pay the $290 for it mentioned on that page.
    Also, as a slightly temporary fix, turn down the levels on your amp. If it has bass boost, turn it off. Lower the dB and the frequency. This just makes it so you wont have to completely remove your setup so you wont damage your sub, it does not give you leeway to play your music loudly quite yet ;p
    ps. is anyone else having trouble when typing "I'm" in firefox? Mine opens the search box and its pretty annoying, lol.
  10. bee2643
    7 Mar 2002
    no i payed $350CAD for the sub, box, and amp, which is a 400watt amp.
    im hoping thats not too much
    i am bridging it so i guess ill take the bridging off so it sounds better. in the future i will consult you guys again on what to upgrade first, the 400watt amp or this 600watt sub.
    thanks! :)
  11. MaximumShow
    20 Jan 2003
    I don't blieve you are overpowering it. The specs on the amp are really needed.
    if your amp puts out 200W per channel to 4 ohm, then bridging it will give you 400W but at 8 ohm. The sub is a single 4 ohm voice coil, so the load on the amp is too heavy. This means that you would be clipping it, and hearing massive distortion.
    But like I said, I can only guess untill I have the specs.
  12. micb
    micb Minimodder
    4 Sep 2002
    Leave the amp bridged, that will give the best amount of power, the 4 ohm load will be fine.
    Bottoming out sounds like a loud rapid clacking sound, this happens with a driver is pushed past its mechanical throw (excursion) limts.
    Distortion is different, is sounds like the music you are playing but worse.
    My bet is that your are not overpowring the driver but actually clipping the amp, this is what happens 9 out of 10 times.
    Most subwoofer drivers can take mechanicly more than there rated RMS, but thermally they my not be able to, it really depends on the subwoofer driver.
    I run over twice the RMS ratings to my both front speakers and my subwoofer in the car, as log as you are careful with the setup and volume control then this is fine.
  13. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    your clipping the amp
    at the end of the day that is the limit to the volume you can get
