Nice work. I can run my single card test again at the required res later. No problem. We need this on the first post though. Could also do with a numerical section as well as the bar graph so we can see GPU clock speeds, CPU type etc.
GPU Category: 2 Way SLI | Resolution Category: 1440x900 Gigabyte GTX 460 in 2 way SLI on 1440x900: Core 910MHz | Memory 1GB Good work Yslen, now could you please put my result over and above LennyRhys score!
Thanks everyone I'll update the chart tomorrow some time, and add in a table as well with all the useful info on it. As for putting it in the first post, it'll just keep overwriting chart.jpg in my image storage, so we just need AoE to drop the link into his original post and I can keep updating it...
Yeah, that's what I do in the Geekbench thread. I host it on my domain, and overwrite the files. bloody_pete just had to put a link on the first post. Works just fine.
How are people just posting the results - are you getting some kind of graphics output? All I can get is html, so I've taken a screenie of the results and posted that:
Mine own little KFA2 550Ti LTD OC White Edition. Cranked up a bit more to 1025/2050/2525 from 1000/2000/2300 Only hits about 53 at load, and that's if I let my room heat up far too much. I need an upped vcore limit to have some real fun with it. Edit: For reference; this is literally just the KFA2 560Ti Ltd OC White edition card with a 550Ti chip in there instead. Hence the brutal amount of power phase and the like I get to play with. Aaand the GPUz readout so I don't have to quote the full lot of information here.
Do you have an official benchmark topic over here with a leaderboard for heaven? If not, now V3 is out, maybe you should have one? I would be happy to run it.
Here's my shot with v3.0 at the same settings as indicated by the OP. Also, I forgot to turn on HWINFO/AB during the benchmark, but the temps tend to max out at 60c and 70c for the VRM. Oh and my CPU is an i7-2600k @4.5Ghz with 1.32v, 8GB DDR3 RipjawsX @1873mhz 8-9-8-24-1T and a Gigabyte GA-Z68X-UD5-B3 mobo (not sure why my sig didn't update).
