Overclocking Unigine Superposition benchmark thread
Discussion in 'Hardware' started by Guest-44432, 15 Feb 2018.
  1. Guest-44432
    Guest-44432 Guest
    A new benchmark thread with Unigine Superposition benchmark.
    https://benchmark.unigine.com/superposition
    So this is just for fun, so overclock as you will and bench away. :)
    Once we get a few results, I'll make a fancy table.
    So the rules are;
    Run Either/Both Presets 1080p Extreme or 4k Optimized
    Post a screenshot with your results along with your GPU Core and Memory clock speeds.
    So I'll go first for an example;
    GPU Core 2050MHz - Memory 6000MHz:D
    adidan likes this.
  2. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Will have to get my rig built and have a pop at this the weekend. :clap:
    Guest-44432 likes this.
  3. The_Crapman
    5 Dec 2011
    Just got my new rig running. so with 7700k@4.8 and 16gb@3333, but 970 is back to stock, max boost 1379, mem 7000. Need to get back on the bios tuning!
    Or a new gpu
  4. RedFlames
    23 Apr 2009
    If anyone wants a laugh -
    Guest-44432 and The_Crapman like this.
  5. Vault-Tec
    30 Aug 2015
    All 1080p extreme as it seems to give very accurate scores :)
    Fury X @ 1125mhz with 8 core Ivy @ 3.4
    My old Titan XM 1458mhz and 4.5ghz 5820k.
    My 14/28 BE running turbo max on each core (as I explained elsewhere) and 2200mhz on the TXP (big pee)
  6. Guest-44432
    Guest-44432 Guest
    I'll have to have another go since I upgraded the CPU. :)
  7. Vault-Tec
    30 Aug 2015
    It does like a core or ten. I was surprised that I managed to level every 1080Ti, because my CPU only clocks to around 2.9ghz or so.
    It's a good DX12 bench tbh and I love that they give a nod to Tesla and co as well.
  8. Guest-44432
    Guest-44432 Guest
    4790k @ 4.6GHz
    1080Ti 2050/6000
    1080p extreme
    4k Optimized with the same clock settings. (CPU has made no differences to the 4k results, even with an etc 200Mhz and HT.) Shame I forgot to run the 1080p preset with the 4670K.
    It does like more cores, but CPU clock speeds don't make hardly any differences in this test. That's why I never bothered to clock to 4.8GHz
    It sure is indeed. :)
    Vault-Tec likes this.
  9. Vault-Tec
    30 Aug 2015
    I will have a play with the 4k one when I get home on Sat. I don't think I've even ran it yet :S
  10. The_Crapman
    5 Dec 2011
    Got my Sata to 4 pin molex adapter today so could power up the pci extender. power and temp to max, +100 on core to boost to 1479, +345 on mem for 3850 and added 250 to the score.
    Had a REAL lazy (so don't know what i'm doing on these chips) overclock on the cpu yesterday and had a couple of sketchy boots today so bumped back down to the auto XMP profile, 4.5mhz and ram at its rated 3400
  11. alfizzle
    alfizzle Ooh aah just a little bit..
    3 Apr 2013
    1080p:
    4k:
    Spec: 8700k @ 5.1ghz core, 4.6ghz cache, 16gb Ddr4 3600mhz 16-16-16-36, 1080Ti @ 2063mhz core, 60003mhz mem.
  12. The_Crapman
    5 Dec 2011
    Core now at 1531, memory at 3953
    I need to find a way to get some airflow to my backplate because it is getting toasty! :eeek: Could always turn my fans up but then it'd be noisy :nono:
  13. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Not bad for a 8 or so year old platform. ill do another run with the GPU overclocked and the x5650 pushed to 4Ghz.
    x5650 @ 3.85Ghz
    GTX 1080 at stock for now. DDR3 @ 1400Mhz
  14. Spanky
    Spanky Minimodder
    14 Apr 2010
    Just run this and its completely borked my GTX 780 :( ... stupid thing said i didnt have enough memory and did i want to run it anyway ..... Yeah ok sure ... BAM!! BSOD and killed the card. Didnt realise a bit of software and destroy a card. Beware!
  15. The_Crapman
    5 Dec 2011
    Holy cow! :jawdrop: Feel really bad for you man. No hope of recovery?
  16. RedFlames
    23 Apr 2009
    That sounds like the card was about to die anyway tbh...
  17. Guest-44432
    Guest-44432 Guest
    Sorry to hear this dude, but I have to agree with RedFlames, that your card must of been on it's last legs before cutting off. If your GPU was getting too hot, then it would throttle back, or worst case, shut your PC off completely.
  18. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I don't see the point of these things unless you have the absolute top end gear, just feels like pointless epeen if u can afford it.
  19. Vault-Tec
    30 Aug 2015
    Mostly, but it is pretty stunning.
  20. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Meh it's kinda like mercedes winning everytime cos they have the best car.
    Ah well
