Windows United Kingdom Keyboard layout not available
Discussion in 'Software' started by batsman, 22 Sep 2003.
  1. batsman
    batsman the quiet one
    14 Nov 2001
    Just finished reloading windows, and just realised that i'm setup with a f'ing american keyboard, and at the moment can't change it.
    I have gone through all the settings in the language options and when i select change inpit language to united kingdom, the keyboard layout drop down only shows united states layouts.
    any ideas how i can reinstall the uk keyboard layout with out reloading windows.
    thanks
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    control panel -> keyboard -> hardware does it for me!!
  3. batsman
    14 Nov 2001
    yeah the problem machine is XP pro, think that only works for 95,98, ME & NT
  4. Darv
    Darv Bling!!
    12 Aug 2002
    It should work in XP. I did it on a friends XP machine.
    On windows 2000 its: control panel -> keyboard -> input locales -> change and then there's an option to install any language.
    It should be the same for XP cos they're very similar
  5. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    control panel -> REgional and Language options -> Languages -> details
    select keyboard and click add, then remove US :)
  6. batsman
    14 Nov 2001
    yeah that was the first place i looked, but the united kingdom layout isn't available for selection eg its not been copied of not installed.
    what i need to know is how you add/install/reinstall the keyboard layouts without having to reload windows
  7. white modder
    white modder What's a Dremel?
    19 Sep 2003
    make english (uk) standard and remove the ******* american layout then restart that should do it
  8. batsman
    14 Nov 2001
    Yeah have tried all of those, and none of them work, as again the keyboard layout isn't available for selection. I've formated and rebuilt the machine now anyway, this time it installed the uk keyboard and i was able to remove the us one durring the windows install
    thanks anyway
