Windows "UNMOUNTABLE_BOOT_VOLUME" Help!
Discussion in 'Software' started by Brassfinz, 15 Sep 2005.
  1. Brassfinz
    Brassfinz What's a Dremel?
    31 May 2004
    Hey all. I've been getting the BSoD on power up. the error reads what you saw in the thread title. The only way I know of to fix it is to reformat entirely.
    After I reformat, everything seems to run just fine, even through all of the reboots that I do when installing drivers and updates and whatnot. But then I power down for the night, and when I go to power up, I get the BSoD again. After that, no amount of bios tweaking or restarting will fix the problem. I have to reformat again!
    I have no idea what could be causing this, or how to fix it (other than reformatting).
    Please help me! I'm tired of reformatting every time I power up. Thanks in advance for any help.
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    What hard drive system? SATA can be a PITA on that board without the latest BIOS & drivers.
    And your sigs too big, apart from not showing the useful info. :sigh:
  3. vetlel
    vetlel What's a Dremel?
    7 Apr 2004
    Mmmmm, just went through this pain a few days ago...
    1) If the drive is fat32, run a bootdisk with fdisk. Ok not...
    2) running ntfs or a (sata) raid, the easiest way is to get a old ide drive hooked up and install a windows on there (on that recognizes ntfs and the like) from that win installation run the various system tools to clean the drive...
    3) Don't even try running the partitionmagic bootdisks, they do more wrong then good...
    Hope this helps
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
  5. Brassfinz
    31 May 2004
    Thanks guys. All that info helps a ton. :thumb:
  6. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    If you boot to the windows CD, and go to the recovery console, and run chkdisk /R , it will repair the problem a good deal of the time. :)
