Motherboards Unplugging 12V while PC is On
Discussion in 'Hardware' started by TheMusician, 26 Nov 2010.
  1. TheMusician
    TheMusician Audio/Tech Enthusiast/Historian
    13 Jul 2009
    Would unplugging the 4-pin 12V square-looking PSU cable from the motherboard while the PC is on cause some sort of irreversible damage?
    The PC turns on just fine but doesn't post anymore. Also, if it's dead, would it be safe to pull out and still use the NVIDIA PCI-E card and the SATA HDD transplanted onto another PC?
  2. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    And why would you want to remove this while your computer is running, exactly?
    To answer your other question, you can transplant parts, yes. With the hard drive, I'd strongly recommend doing a fresh install to avoid any driver issues.
  3. TheMusician
    13 Jul 2009
    It was kind of an accident caused by an idiot cousin of mine. Is the motherboard or PSU damaged, probably?
  4. padrejones2001
    17 Jun 2004
    I take it before this accident occurred, the computer booted just fine? If yes, then there's your answer. Tell your cousin he can buy you another motherboard and possibly CPU and RAM. He should probably stop rooting around in computer cases from now on.
  5. sleepygamer
    sleepygamer More Metal Than Thou
    24 Apr 2010
    Is this the extra 4 pin from 24pin, or the 4pin by the CPU socket? I had the former happen to an older motherboard. The 4 pin was always a little loose, and the cable had to stretch across the board, so after a while of running, it came loose. The system kept going until I shut down, and then would not boot. Fried the motherboard. CPU etc was fine.
    If it is the latter, then you may have a dead CPU, as well as a dead mobo and RAM, like the padre says.
  6. Canon
    Canon Reformed
    19 Jul 2010
    The 12v 4's are usually silly short cables, especially on non-modular PSUs, I'd recommend picking up a little extension cable to be on the safe side in the future.
    I buy mine from Maplin, as the shop assistants keep reminding me, it's waaaaay overpriced, but it's there and it's handy. I think it was 2.99 I paid for the extension cable and it was in the aisle along with the fans/system blowers/cables. Just a hint.
  7. mav2000
    mav2000 In Training
    16 Oct 2010
    Plugging in anything or removing anything, including fans while the system is running is going to cause an issue.
  8. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Try unplugging/unsocketing everything, reseating it and a new PSU. Did that to a PC i was replacing a HDD on (Compaq POS, P4 plug was loose when I got it (didn't notice), fell out during a windows 7 install!)
    System booted fine afterwards. Guess I was lucky though!
    Done the fan unplug+replug many times without issue, same with SATA, without issue. Then again I go for premium boards/server boards. Server boards are designed for hotswap :p
  9. Winkle
    Winkle What's a Dremel?
    16 Sep 2010
    Have you tried just resetting the BIOS by clearing the CMOS?
    I don't see why losing power should suddenly cause irreparable damage?
  10. memeroot
    memeroot aged and experianced
    31 Oct 2009
    It might have done but I've certainly unplugged when the system has been on many times....
