Windows Unreal tournament - Critical error (xp)
Discussion in 'Gaming' started by dhutch, 5 Oct 2003.
  1. dhutch
    dhutch Banned
    10 Apr 2003
    I have instaled UNreal tournament on my XP computer - it ran fine and i spent the night shooting my brother (via home network)
    the next day (sunday- today) i instaled a few other progs and then planed to shoot my little bro again - but it cam up with the dumb "CRITICAL ERROR" thing below
    since then i have
    -done a "system restore" back to yesteday
    -reinstalled UT
    - tryed runing it in safemode
    - tryed running it form software rendering
    etc etc
    and i now am getting realy pis*ed off :waah:
    and i need my UT!!!!
    and some one help :confused:
    please!!!!
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    get the very same error, in fact have to install ut from hdd copies cos even that doesn't work.....
    solved it by reducing overclock a little, still woon't install tho'....
  3. dhutch
    dhutch Banned
    10 Apr 2003
    yeah well
    i dont OverClock this comp (at all) and i had now problem installing it and even running it on saturday
    and now although it will still install fine it wont run!!
  4. Krikkit
    21 Jan 2003
    Have you changed any hardware since it last worked? I had a generic DVD-ROM drive installed for a while, only to discover that it totally screwed up every Unreal game (UT, UT2k3, U, U2 and all the games using the engine...). I only managed to fix it once i removed the drive, was a very nasty thing to happen...
  5. Highland3r
    25 Jul 2003
    interesting.... mine screwed up after i installed an athlon XP range processor..... was and i think still is fine with my old t/bird
  6. dhutch
    dhutch Banned
    10 Apr 2003
    surely some one has some ideas
    i have installed the latest update and tryed everthink
    here are my system spec (if any one cares)
    graphics card: SAphire atlantis Radeon 9600 Pro 128MB
    motherboard: Epox 8RDA+ nForce2
    RAM: x2 TwinMOS PC3200 DDR-DIMM 256MB w/Winbond
    cpu: Athlon XP 2600+ 2.08Ghz SoA - 333FSB (not barton)
    oh well guess i jst reinstall windows - DAM - that the third bloody time in 2weeks :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
  7. Highland3r
    25 Jul 2003
    that doesn't work m8, tried that a number of times, hans't helped!
    is the machine prime/super pi stable?
  8. dhutch
    dhutch Banned
    10 Apr 2003
    A) why wont wot work
    remeber it has work on the computer
    B) what u on about "is the machine prime/super pi stable?"
  9. Highland3r
    25 Jul 2003
    huh!
    worked on mine too, but no matter how many re-installs still won't work....
    can you run superpi or prime95 without it crashng?
  10. dhutch
    dhutch Banned
    10 Apr 2003
    wot is superpi and prime95
  11. Highland3r
    25 Jul 2003
    :search: they are stress/stability test proggies
  12. dhutch
    dhutch Banned
    10 Apr 2003
    yeah but how do thay work
    HELP - I NEED UT !!!! :wallbash: :wallbash: !!!!!
    daniel
  13. Highland3r
    25 Jul 2003
    SuperPI (or pifast) calculate pi to a varying number of decimal places. If i can't create an exact number then u get an error.
    With prime, numbers are calculated by computer and compared to a set of know values (i think) any errors = pc unstable, same for both :D
