Modding Untitled Nano-Box
Discussion in 'Modding' started by jonoc, 25 Jun 2004.
  1. jonoc
    jonoc What's a Dremel?
    25 Jun 2004
    These are a couple of shots of my case. This is my first mod and I can't even test it for at least another month. Bad timing for me eh? Either way I like it. As you can see there is a mock-up of the board to the right.
    A different angle...
    A shot showing the inside of the case. Empty for now!
    A birds-eye view. The dimensions at the largest points are 6"x6.75"
    A close-up of the design on the top.
    These were the other two options for the top design.
    I'm wondering about cooling. I originally wanted a 92mm or 120mm right smack on top. That's not possible now because I opted for a design instead. I plan to have a 2.5" hard drive on the bottom layer and the board on top of that. This box did not intend to house an optical drive, I was going to use a firewire one. Anyone have any ideas for cooling? I know a the CPU doesn't create THAT much heat but I'd like to have a nice quiet fan to keep the temp fairly low.
    Thanks everyone!
  2. stoned penguin
    stoned penguin What's a Dremel?
    23 Mar 2004
    dead pics
  3. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Yeah, no pictures..... :( :sigh:
  4. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Fix them pix!
  5. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    :hehe:
  6. jonoc
    25 Jun 2004
    Sorry guys. Can someone suggest a good place to store my pics? Right now they are on Yahoo photos. I'm going to try photo bucket next. I'm workin' on it!
  7. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    www.uploadit.org, or as you've said photobucket, i find the second one better though. :) :D
  8. jonoc
    25 Jun 2004
    Hopefully you should be able to see the pictures above now. If not, please let me know. Photobucket is up and running.
    Thanks for your patience everyone.
  9. Firehed
    15 Feb 2004
    They're good for me.
    Looks interesting. That's one of those via midget-boards right? I'd kinda like to do something with one of them... but I can't afford it right now. For the power you're getting... they're expensive! Tiny though... that's what you're really paying for.
  10. hacker 8991
    hacker 8991 What's a Dremel?
    8 Jan 2004
    That looks pretty good, but you need to look into some better JPEG compression. The arifacting is horrible in those shots.
    As for your cooling question, you could still have a 120mm on the top, just do it ZapWizard style!
    Basically, you just use risers to bring whatever (in this case, acrylic) away from the base a few centimeters. I don't think that you can use watercooling in that small of a computer, so this might be the way to go.
    - tf
  11. jonoc
    25 Jun 2004
    hacker:
    I think that could actually work nicely! You are talking about an outflow fan right? I could make vent holes or whatever all around the base of the case.
  12. hacker 8991
    8 Jan 2004
    It doesn't have to be 'outflow.' As long as there is space around it, the fan could pull air in or out. However, in your situation, I would say that an outflow fan would be desirable.
    Good luck on this case. I hope you can fit everything in :thumb:
    - tf
  13. Le Tordu
    Le Tordu What's a Dremel?
    16 Jan 2004
    Sorry, Ascii art, but the idea is here : you put your mobo s-side-down, and the fan will blow the heat outside via holes or way you want...
    Code:
    |  |  Hard Drive                 |  |
    |  | Up-side-down mobo           |  |
    |  | Fan                         |  |
    ||    <-- air out -->              ||  <-- feet and space for air
    ------------------------------------  <-- botton of the case, cut
  14. SWFREE
    SWFREE What's a Dremel?
    11 Mar 2004
    uhm.. the via epia processor doenst get very hot..you could use the place where the cooling should be for a psu . the psu fan could cool both.. uhm.. yeah you would have to look for a psu small enough.and even then you have to resolder some parts to make it more compact.
  15. Zogthetroll
    Zogthetroll What's a Dremel?
    5 Feb 2004
    or use a small blower, think 92mm dia. and have it exhaust out the back, would work since it could be placed under the lid like the case fan would have been, but would have rear exhaust and the port would only be about 25mm square. about like This
  16. Jedi
    Jedi What's a Dremel?
    16 May 2004
    epia psu don't have fans ....
  17. SWFREE
    11 Mar 2004
    uhm..hes using a epia psu,
    wheres the problem adding a fan?
  18. jonoc
    25 Jun 2004
    As far as power is concerned...
    I don't have enough details about the board to see how the power situation is going to work out. There are plenty of DC-DC converters like this that will provide enough power, displace little heat, and are very compact. If you look at the picture of the board here you can see in the upper-right corner (go into the download section to get a hi-res version) a proprietary power connector, so i'll just have to wait. Another version of the ITX board has an integrated converter so you plug in a brick, laptop-sytle PSU; that's what I'm hoping for.
    About cooling...
    This is the way I see it: The connectors need to come out of the back, so the back is pretty much out of the question. As mentioned above (1) I could line a 92mm or 120mm with the top edge and use some nice stainless steel risers to raise the roof a bit, allowing the flow or (2) do the same thing but on the bottom, flipping the MB upside down; tricky, but managable.
    Any other suggestions would be great! Thanks for all the replies!
  19. jonoc
    25 Jun 2004
    Oh yeah, and the board comes with a noisy fan and a heatsink (usually epoxied to the CPU. I want to ditch the stock fan and just go with one large casefan.
