Windows Unusually long Booting
Discussion in 'Tech Support' started by TeenGeek, 4 Sep 2012.
  1. TeenGeek
    TeenGeek Worst touch typing ever.
    11 Feb 2011
    Hi all, i recently built a computer, and for a while it was booting up so quickly that the windows orbs couldn't even become the windows logo. Now when i start up my computer, it stays at the starting windows screen, with the windows logo, and takes a much longer time to actually get into windows. it used to be about a 20 second boot time, now it is around 45 seconds or more.
    -thanks in advance
    Also, i was wondering if it could be a disc formatting issue, as i have never built my own computer before this one, and it has an SSD that i suppose should be formatted, so i was wondering how hard/ how long that would take (i already have a windows image/backup on my 3TB storage drive.)
  2. Zurechial
    Zurechial Elitist
    21 Mar 2007
    If you've mounted any network drives they can add considerably to your boot time because, for some reason, even Windows 7 thinks it should delay the whole booting process to scan/wait-for network drives.
  3. TeenGeek
    11 Feb 2011
    as far as drives go, the only things that i have on my computer are my boot drive (OCZ vertex 4, a seagate barracuda 3TB, and misc. usb drives/ usb CF readers that usually arent plugged into the computer on boot.) we don't even have a network of any type set up at the moment, since we just moved... my computer is pretty much the only one in the whole house
  4. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Un-plug the 2nd HDD and see if it's quicker, or run diskcheck to see if there are any filesystem errors.
    dunx
  5. T2I3M
    T2I3M Minimodder
    13 Mar 2010
    Have a look in msconfig on the startup tab and disable all the startup items. Then reboot and see if the startup time increases. If it does, start to reenable some of the disabled startup items.
  6. RocketPotato
    RocketPotato What's a Dremel?
    4 Sep 2012
    Agreed, MSCONFIG is your friend for boot-up time issues.
