Modding Up and Running
Discussion in 'Modding' started by modsquad, 16 May 2004.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Had a few days off work so I decided to get this thing up and running. No real problems to speak of (DVD rom drive covers are bindind and need a trim and no HD or POWER ON leds, flip the leads?). I have on worked on that, just installing software (3Dmark03= 6048). Check out a few "no-flash" pictures. I hate to "toot my own horn" but the pictures don't do it justice. I could not be happier with the outcome. A big thank-you goes out to G-gnome and his Orac (that was the reason I started this project) also Coorz and his Plexeon.
    http://server5.uploadit.org/files/jeffrey9-running.jpg
    http://server5.uploadit.org/files/jeffrey9-running2.jpg
    MS
  2. coorz
    coorz Miffed
    25 Apr 2003
    Thx and congratz for having your rig up and running. I assume it's not finished yet ?
    Got some daylight pics of the insides?
  3. modsquad
    27 Feb 2004
    No, Still working software. Inside is messy, I need to work on it. I am having problems with my MATRIX ORBITAL (not the display but the software), I know this guy is "friend" of this site,but the LCDC software is buggy. His display is great, but without solid software____I have a expensive clock.
    Also the internal USB cable he sells is "just long enough" and this is a mid-tower case. Please add a few inches dude...
    MS
  4. modsquad
    27 Feb 2004
    Here's a few daylight pictures. Like i said needs work. There is less room inside the case than i invisioned when i started.
    http://server5.uploadit.org/files/jeffrey9-inside1.jpg
    http://server5.uploadit.org/files/jeffrey9-inside2.jpg
    MS
  5. coorz
    coorz Miffed
    25 Apr 2003
    Mmm, LCDC works fine in my Plexeon. Only probs come when i switch of the LCD when LCDC is running, otherwise i had zero problems with it.
    Spot on about the internal USB cable. Luckily i didn't bought it, i just soldered two cables together, also barely long enough.
  6. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    lcdc is a great peice fo software, what plugins are you using? it tends to be some of the 3rd party ones that cuased any issues i had.
  7. modsquad
    27 Feb 2004
    Only MBM. I got LCDC reading MBM correctly now, it was a mater of changing settings in MBM not LCDC. I also had the LCDC virtual display stop working, but it's working ok now.
    But I have no idea how to get the dallas one wire probe working, LCDC finds it, lists it, but nothing shows up on the display. Do you need to build a screen to make the thing work. The manual is not much help.
  8. Xen0phobiak
    8 Aug 2002
    Not used the dallas probe, its not on my lcd. You will need to show the probe reading on a screen yes.
  9. modsquad
    27 Feb 2004
    Yes, that is what I want to do. I have a reply on the LCDC forum from Matt Augier, I am going to see if I can figure this thing out with his info.
  10. modsquad
    27 Feb 2004
    I am in business, I just needed to be pointed in the right direction. My temp probe works great.
    MS
    http://server5.uploadit.org/files/jeffrey9-running3.jpg
  11. modsquad
    27 Feb 2004
