Upcoming release of SMP2 cores
Discussion in 'bit-tech Folding Team' started by Christopher N. Lew, 24 Jan 2010.
  1. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
  2. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Have updated one of my linux box's to the new core.
    Have not had much luck trying to put the new core onto my notfred's machine thu.
    Just have to wait for NotFred to update the VM i guess...
  3. Synay
    Synay What's a Dremel?
    25 Oct 2009
    I got one of those new a3 jobs, but what a drop in PPD!!! With older WUs I was getting ca. 3300PPD, and now 990.
  4. cdb
    cdb No comment
    25 Apr 2009
    Let us know what you get when it's fiished with the bonus.
    What cpu at what speed are you using?
  5. Synay
    25 Oct 2009
    I will do. I use Intel Core2Quad Q9400 OC'd to 3.53GHz. Still about 5 hours to finish though.
  6. Christopher N. Lew
    23 Apr 2009
    That's because FahMon can't deal with the new bonus system. Your figures are similar to those mentioned on the Stanford Forum, so you should get a reasonable bonus. (Anyone know how to look up what a bonus was given to a completed WU?)
  7. Tesla effect
    Tesla effect AKA ZombieKiller1
    24 Jul 2009
    Try HFM.NET, although I think that it's only reporting a base figure without the bonus...At least I hope so. Fahmon is reporting 941 ppd. HFM.NET reports 4623. This is on a Q6600 OC'd to 3.4GHz.
  8. Tesla effect
    24 Jul 2009
    HFM.NET is apparently calculating bonus. Hopefully the calculation needs to be fine tuned as it will obvioulsy only have been used for bigadv wu's until now.
  9. Tesla effect
    24 Jul 2009
    It could of course just mean that I dont qualify for bouns yet? I dont know how that could be known, I have folded with this passkey just not for a while.
  10. Tesla effect
    24 Jul 2009
    HFM.NET does report ppd with bonus.
    Caution, my personal conclusion is that using core A3 is highly likely to result in a ppd drop on a Q6600.
  11. Synay
    25 Oct 2009
    Interesting, it seems that overall credit you get depends on how your CPU is performing. If I leave it and do nothing it reaches 2700 points, but if I for example turn on some other application, thus using some of the cycles that would normally go towards folding, time to return the WU is longer and the credit gets smaller (2300 points as I write this in a Firefox browser with two tabs opened, for example).
    Overall PPD seems o be around 4950 on Q9400 OC'd to 3.53GHz. That is a massive step up from what I had before the update to 6.29. I will leave it for some time now and see if my overall amount of points I receive every day will increase, confirming what I just wrote, or drop - confirming what Tesla effect wrote.
  12. Tesla effect
    24 Jul 2009
    Reported PPD seems to increase over time or with more completed wu's. My Q6600 is currently back at a2 benchmark level.
  13. Synay
    25 Oct 2009
    It seems, that I got 2023 points for the a3 job that took ca. 12H to complete, yet to confirm this though. But it also looks like it takes ages for stanfort to process the result, add the bonus and put it to update.
  14. StreetSam
    StreetSam Minimodder
    30 Aug 2005
    I updated and ignored, but now I have seen this thread I went to look. My bog standard Q6600 used to run (SMP under windows) at ~1200PPD but HFM is now reporting 3000+PPD so I'm happy :D
  15. Tesla effect
    24 Jul 2009
    Yes indeed, an unfounded & rash conclusion on my part.
    The 6.29 client with the a3 core running 601x projects rocks :clap:
  16. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Not got any of the new ones yet on any of my 10 CPU's, will be interesting to see which ones get effected more having such a mixture of AMD/Intel Duals/Quads...
  17. darkorb
    darkorb What's a Dremel?
    13 Dec 2009
    Mmmm can't wait to try these out once the current WU's finish... Should be interesting to see how much of a difference it makes running them native on some of the Windows boxes I have (the part machines).
  18. Frank_Kehoe
    Frank_Kehoe Folder
    23 Apr 2009
  19. darkorb
    13 Dec 2009
    Cool, thanks for that link.
    I've just converted over 5 of my full time machines to the new A3... 4 Quads, 1 Dual so will keep an eye on the PPD of those and see what happens.
    One thing I have noticed right away is it seems more efficient in the way it spawns, there's a single process on my Linux boxes rather than the 1 per core that I was getting before. So far it's sat at a flat 400% (i.e. 100%) where as the older setup used to bounce around between 90%-100%...
    Anyway, time will tell I guess. Will be nice to get my PPD back up to normal :)
