Graphics Update GPU driver.....
Discussion in 'Hardware' started by Kronos, 1 Jun 2015.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    Clean install each time or not?
    The reason I ask is on upgrading to a GTX 980 from the 670 I had so many issues likely caused by not clean installing the latest drivers that it took a complete Windows install to sort things.
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Clean install of what?
    The OS, using a driver cleaning program, or using the built in clean install when installing the driver.
    I always use the custom/clean install option of the drivers when installing newer version even on the same OS and card, if I upgraded to a newer card I would un-install the driver > shutdown > swap cards > re-install driver.
    I would only do a full re-install of the OS if something didn't seem right, like high temps or low FPS, and using a driver cleaner didn't sort it out.
  3. Yadda
    Yadda Minimodder
    25 Jul 2003
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    No clean install of driver. I only reinstalled Windows because of the many issues I was having and it was simpler than trying and probably making worse the problems I was then having.
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    As I have said by the time I decided on a reinstall of Windows my issues with the new card or drivers were many and it was simpler to reinstall the OS ETC.
    MY original question concerned updates to GPU drivers. use the clean install option or not.
  6. Yadda
    Yadda Minimodder
    25 Jul 2003
    Kronos, didn't you have to reinstall the OS because you somehow FUBARed the video drivers by not removing the drivers for your SLI 670 cards before installing your new card?
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    Err yes. But my question is still about driver updates of which I had a notification of this morning. Should you clean install such an update which is offered or just overwrite which I have tended to do in the past with no issues?
  8. Yadda
    Yadda Minimodder
    25 Jul 2003
    I see, apologies.
    I can't really help you with that because I do it the old fashioned way, by downloading the driver myself, removing the old driver manually as per Nvidia's instructions (linked to in my post above) and then installing the new driver. I've never had a problem doing it that way.
  9. Tichinde
    Tichinde Minimodder
    1 Sep 2010
    "Dirty" installs all the way.
    Geforce experience says it's time, I tell it to crack on.
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    So no consensus. Thanks all.
  11. jinq-sea
    15 Oct 2012
    FWIW I let GeForce Experience manage the downloading of updates, and I then install the driver and make it do a clean installation. I find it a reliable way of doing things.
  12. Yadda
    Yadda Minimodder
    25 Jul 2003
    Is Geforce Experience any good? I only gave it a brief look some time ago before shuddering in fear vowing never to return (auto game settings? No thanks!). Maybe I should have another look.
  13. Parge
    16 Jul 2010
    For an update, you’d be mad to do a clean install. You’d be reinstalling every two weeks.
    Only time I do a clean install is when swapping between AMD/NVidia.
  14. Yadda
    Yadda Minimodder
    25 Jul 2003
    Kronos means "clean install" as offered in the Nvidia driver installer options, not a OS install.
  15. mrbungle
    20 Sep 2004
    Upgrading drivers when you have no current issues will only bring you the possibility issues.
  16. Corky42
    30 Oct 2012
    Updating drivers isn't just related to fixing issues, in some cases it brings a marked performance increase or even a decrease, I guess those could be classed as issues it's just difficult to know if that issue effects you without testing.
  17. Yadda
    Yadda Minimodder
    25 Jul 2003
    Wise words. That's one good thing about using older hardware: no more driver optimisations means less faffing around (..until it goes EOL).
  18. mrbungle
    20 Sep 2004
    Wise words from a AMD user.
    Cat 14.9's have been a nightmare for me, random black screens while browsing and idle is enough to make you scream lol
  19. heir flick
    heir flick Minimodder
    2 Feb 2007
    same here, updated the last 3 nvidia drivers like this problem free
  20. Digerati
    Digerati Minimodder
    19 Feb 2011
    Same here. I only do a "clean" install when swapping cards or if the "dirty" install (update) fails - but frankly, I can't remember the last time a graphics driver update failed. I don't think it has ever happened with any of my W7 or W8 systems and I avoided Vista so it must have been with XP.
    But since W7 and W8 are not XP, I don't do things today with W7 or W8 just because those things needed to be done with XP.
