As promised, here are some better quality pics of my modded Cyber Fusion (now with Cold Cathode), still not the best quality, but better than the last set: Here's the cut 'n' paste incase you didn't read my other thread: 'The first thing I did was give it some bloo LED action. Then I cut a big old window in the side. I've got a small bloo neon in there at the mo, but I have a Cathode coming tomorrow to replace it. I modified the bottom 5.25" bay into a dual intake by trimming some of the cage back, and moving the 2 80mm YsTechs to the bottom, placed some chrome guards on them, then I cut some blow hole duct in half and glued the 2 pieces into the drive bay opening, after dremmeling the cover to take them. I have cut out the 80mm pressed guards at the back of the case, and replaced them with chrome finger guards. I also have a 16x2 VFD in the front. So what do you think?'
Look at the top of the case, you can't really make it out in the pics but thats a Bit-Tech badge!!!!!!!
