Equipment upgrade advice
Discussion in 'Photography, Art & Design' started by Shadowed_fury, 9 Sep 2008.
  1. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Currently own;
    300D - needs replacing for 400d/450d really
    70-200F4L - perfect
    kit lens - die
    Anyway, i've got a budget of around £200. And need to fill some voids, I want to start using flash, but it needs to be manual really, so 580ex II kinda thing.
    Again, I need a replacement for a kitlens or similar area, anything from mental wide to 70mm really :)
    And then the body, urgh. Why must the 300D be so slow. :p
    Basically, i'm looking for pointers to good lenses for £200~ cos i'm not sure atm
  2. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    Tamron 17-50 f/2.8 and Sigma 18-50 f/2.8 are both fairly solid bets for a walk-around lens. If you're after a bit more reach, the Sigma 24-70 f/2.8 might be a more suitable option, but 24mm isn't particularly wide at all on the 300D.
    Also just with regards to the flash, why does it need to be manual....and why does that lead you to the 580EX II? It's a pricey flash to be using just in manual mode - you could get away with a cheapo £30 flash off ebay in that case.
  3. Shadowed_fury
    21 Nov 2003
    Thanks for your reply Nath, where can I pick up the first two lenses for around £200? They are exactly what I was after actually, struggling finding good prices though.
    Which is better too? :)
    The flash thing is simple, once I delve into the flash route, I wanna take it quite seriously - been reading up on strobist for some time, so don't wanna waste my time with a flash thats just not gonna cut it. Even more so when I'm using 2-3 flashguns at once :)
  4. Vers
    Vers ...
    23 Oct 2007
    I never really saw any point in 'upgrading' from one xxxD series to another. IMO it may be time to look for a good used 30/40D--or even better, if you can afford it/save up for, a new 30/40D. As for a kit replacement, as always, try out a Tamron 17-50, Sigma 18-50 macro, or a Sigma 17-70 (great range, but variable aperture)....trust me, if you go with one of the **-50mm's you will not miss the 51-69mm range all that much as long as you have your 70-200 with you. For flash, look into the new 430EXII--it should do everything you ask. Also, while it may not rank that high on your priority list if you like to shoot in natural low light perhaps its time for a fast prime? Nifty 50/50 f/1.4 and or 85 f/1.8 are all excellent choices :thumb:
  5. Shadowed_fury
    21 Nov 2003
    Thanks Vers :)
    Yeah the 70-200 is very versatile indeed! As I noticed yesterday (see photos).
    I'll give those lenses a look over now.
    What sorta control does the 430EXII offer me? I know it can act as a slave, which could prove useful in the future I guess :)
    I also was tempted to get a 30D second hand, but for some reason i'm put off because of the shutter life. Not many people on ebay list these!
  6. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    http://www.onestop-digital.com/catalog/product_info.php?cPath=24_28&products_id=87
    http://www.onestop-digital.com/catalog/product_info.php?cPath=24_29&products_id=301
    Its worth paying for fedex delivery though.
  7. Shadowed_fury
    21 Nov 2003
    Xen0 you legend! Thanks! :)
  8. Vers
    Vers ...
    23 Oct 2007
    430EXII
    Look to see if you can find a refurbed 30D...or perhaps some overstock.
  9. Shadowed_fury
    21 Nov 2003
    That 430EXII does look good Vers, I think I'm gonna spend some time deciding between that and the Tamron.
    I've just noticed you have one of the Tamrons infact, any sample photos that you mind sharing? :)
    Thanks!
  10. Vers
    Vers ...
    23 Oct 2007
    I use it for work, outside of that I really haven't used it all that much--here and there messing around, but nothing worthwhile. If we get some decent weather here in NY I'll make an attempt to get out and shoot a thing or two, until then there are plenty of others here on the forum that can provide you with some samples. Here are some samples posted on FM
    Review
    Photozone
  11. Shadowed_fury
    21 Nov 2003
    Thanks again Vers, 430EXII or the Tamron now then. I'll weigh up my options :D
    Oh, and i'm gonna start saving for a 30d/40d now. Will I notice a difference, in image quality when I upgrade at all?
  12. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    If you are serious about this and don't want to waste money, forget the 430EX. It lacks even the basics for an off camera flash. I doesn't have a PC Sync port and it doesn't have a dummy optical trigger. To get the 430ex off camera you are limited to the Canon IR system, for which you'll need to buy a master unit and learn to work with it's limitations. Or you'll have to get an eTTL extender cable, which is pretty short and expensive. Or you'll need to get a PC sync-hot shoe adapter that fits on the bottom of the flash, which for me, is another point of failure and added expense.
    Decide if you want to use radio triggers or the IR eTTL system. For the IR system, just buy the 580 now and save yourself the hassle later. If you want to go with the radio triggers, then head to ebay and look for any flash with a PC Sync port. A lot of Canon shooters are using old Nikon SB-26s and SB-28s due to them being so common, although I understand that they have become more scarce due to the Strobist site.
    Check this discussion for all your 430 off camera questions. There are 1,332 threads about it, so you should find what you need.
  13. Shadowed_fury
    21 Nov 2003
    Thanks for that JJ, just what I wanted to hear really. I'd much rather get the 580EX II at the end of the day, it might be overkill right now, but its better than outgrowing the 430EX II ;)
    Those radio triggers i've seen on ebay/gadget infinity are apparently fine. I know a lad who uses them with a 40D/2x580EXII/550EX setup with no problems at all, and for the money you can't go wrong. I'm sure you know which I'm harking on about! :)
  14. Vers
    Vers ...
    23 Oct 2007
    Overall...yes, I think you will--even more so with the 40D. Handling and ISO performance alone is enough for most to upgrade.
  15. Shadowed_fury
    21 Nov 2003
    Good! Yeah the ISO bit is mostly what I crave, its awful on the 300D, more so compared to my girlfriends D80 which is quite impressive!
  16. Vers
    Vers ...
    23 Oct 2007
    Don't expect miracles...but it is a noticeable difference.
  17. OleJ
    OleJ Me!
    1 Jul 2007
    I think you need to hold a 300D again.
    The step up for me from the 350D to the 40D was almost miraculous when speaking of ISO. With the 350 I couldn't stand the noise when I went above ISO400. 800 was only just bearable but not really an option unless I planned on going B&W.
    Then again: I didn't expect the degree of improvement that I saw so I was of course very very impressed.
    And as someone posted in another thread the 40D is now $100 cheaper than the 450D... IMO it would be crazy not to opt for the 40D then.
  18. Vers
    Vers ...
    23 Oct 2007
    There is a difference...there is no doubt, but its not like the difference between the 300D and a 5D--that's miraculous.
  19. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    I love the photos my 300D takes at iso 100 & 200, beautifull! When i get the focus right anyway... my excuse is the viewfinder is a little too small making it hard to be accurate with a shallow dof :grr:
    How much larger is the viewfinder on the better canons, such as 40D, 5D?
  20. Vers
    Vers ...
    23 Oct 2007
    40D is 95% (0.95x mag), 5D is 96% (0.71x mag)--both are brighter than the 300D.
