Build Advice Upgrade Advice
Discussion in 'Hardware' started by b0ng0, 4 Jun 2010.
  1. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    Upgrading from:
    Motherboard: Gigabyte P35 DSL
    CPU: Intel Dual Core E2220 2.4GHz
    Memory: Corsair DDR2 6400 XMS
    GPU: nVidia 260GTX 956MB
    PSU: Tagan Whisper 450W
    Case: Coolermaster Centurion
    Upgrading to:
    Motherboard:MSI 770-C45
    CPU: - AMD Athlon II X2 250 3.0GHz
    CPU Cooler: Arctic Cooling Freezer 7 Pro v2
    Memory: Corsair XMS3 DDR3
    Case: Antec 300
    PSU and GPU staying the same.
    I'm not looking for top performance, just a cheap upgrade to get a bit more performance for gaming and also to match the GPU which I feel is probably bottlenecked a bit by the CPU.
    Thanks for any advice. :geek:
  2. adam_bagpuss
    24 Apr 2009
    thats isnt really an upgrade just a switch from intel to AMD except you have added 2GB more RAM.
    my advice is aim higher or add an extra 2GB and good cooler to your existing rig and overclock the CPU
  3. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    I hear what you're saying im just not too keen on upgrading the RAM to DDR2 when it will be redundant if I upgrade my motherboard (plus 4GB DDR2 is still quite expensive).
  4. Sexton
    Sexton Minimodder
    2 Jun 2010
    Looks good to me... if you're running Windows Vista/7 then the RAM should make quite a difference - when I jumped from 2GB to 4GB I noticed an incredible speed boost. Can definitely vouch for the CPU cooler anyway - same as I'm running - keeps my 7750BE at a steady 20 degrees.
  5. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    You OCing your CPU?
  6. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    I will give OC'ing a shot today. I've only overclocked an Athlon 64 before, so this is gonna require a bit of reading. Maybe just get some more RAM from eBay to save on cost eh.
  7. adam_bagpuss
    24 Apr 2009
    oo god please dont.
    you get zero warranty and could end up with faulty RAM.
  8. b0ng0
    b0ng0 Reddomitlum
    26 Oct 2009
    Oh really? Ah well... maybe I won't then!
  9. montymole
    montymole Rigid Tubist
    24 May 2010
  10. bagman
    bagman Minimodder
    18 Apr 2009
    what cooler do you have atm?
    you should be able to get that chip to 3.2+ with a half decent cooler
    a cooler and 4gb ram is what you need
    what is your hard drive like?
    could be worth looking into a samsung F3 500gb drive they are really good
  11. Akuman
    Akuman Waffles
    5 Jun 2010
    Don't know if you're running on 2 gigs or 4 gigs of RAM atm, but if you do upgrade from that 2 to 4, I suggest you get a 64 bit OS seeing as 32 bits won't be able to use 4 gigs.
    Not sure if you've already thought of it, but thought I'd mention it just in case :D
