Other Upgrade for 100$
Discussion in 'Hardware' started by ComputerKing, 15 Nov 2011.
  1. ComputerKing
    8 Sep 2006
    Hello Guys :)
    I got my self an upgrade :) didn't cost much and It didn't make a difference I think :(
    EP45-UD3R + 2*2GB 1066 Kingston HyperX
    I had A 2*2GB Transcend 1066 + 2*2GB Kingston 800 so that what I replaced ...
    Now First problem When I open Bios or CPUZ it reads rams running on 333mhz 1:1 5/5/5/15/44/2T and in each ram it's avaiable JEDEC #3 400
    so how i can fix to run on 400 mhz default speeds ?
    Second is temp problem, Cpu still running as hot as my old temps readings from the other motherboard :( I did clean every thing and AS5 :( and still idle at 54 / 53 / 44 / 48
    I got good air flow and Enermax Cluster fans running 1.3 K ! 4 of them :) cost more than the hardware it self :p
    old
    hardware
    new build
    So What I can do :duh:
  2. samkiller42
    25 Apr 2006
    CK, Your back:thumb: Sorry i can't answer your question, but felt the need to welcome you back!!
    Sam
  3. ComputerKing
    8 Sep 2006
    thanks Sam ;) I really miss being here around you guys ( you are my family :) )
    It's okay :) I just tought I post a new update when I come back :) it's not a killer hardware any more like back in 2007 ;) DAm I was at the top :) now i just use it for paper work :duh:
