Though I find its performance fairly good and reasonable range much better than HH3, I am looking to upgrade budget around £200 any suggestions / recommendations? Would prefer a complete router that I can plug straight in as a straight replacement for the HH5 Thanks DM
Are you using the built-in modem in the HH5 or the separate modem? If the latter then you can buy any router you want so long as it has an ethernet WAN Port.
Hi, I am using the built in modem within the HH5 However I still have the original white BT ADSL modem that fed my HH3 prior to the 5 which would allow me to consider a separate router not sure what is best at this stage so open to suggestions, my budget remains £200 for just the router. Thanks, Simon
Yes it is just a router that I am looking for one that is an improvement over the 5 with USB 3 port/s and a good solid WiFi signal. Thanks Simon
The ASUS RT-AC68U seems to get pretty good reviews, and you can install custom firmwares like Tomato, Merlin and OpenWRT. I'm in the market for a decent router myself (Virgin superhub for the fail) so keep us posted on what you get.
Beware of the fact that if, like myself, you are on Option 4 (FTTH - 330Mbps) it's Homehub or nothing!
