Build Advice Upgrade my base mother board to x99?
Discussion in 'Hardware' started by rainbowbridge, 9 Oct 2014.
  1. rainbowbridge
    rainbowbridge Minimodder
    26 Apr 2009
    If you had the following and wanted to upgrade your system board and cpu (and ram).
    What would you get?
    I am thinking of going 980SLI in near future once I lose the 7880ti
    Mother board:
    P8Z68-V PRO
    CPU: i7 2600k
  2. andrew8200m
    andrew8200m Modder
    4 May 2009
    Not much difference between an 780ti and an 980 really.. Id just get a second 780ti and save yourself a few hundred quid.
    X99 is great but DDR4 is mega bucks and none of the X99 CPUs hold any real advantages over the previous gen or haswell unless your going for mega number crunching to which you need to spend £1k+ on the CPU.
    Id get an Z97 board of some description, some fast DDR3 and a 4790K. Youll be around £1k better off and barely any slower in your system over all unless you plan on ripping blu-rays and encoding other video sources.
  3. rainbowbridge
    26 Apr 2009
    -Asus X99-DELUXE ATX Motherboard Socket 2011-v3 Intel X99
    -Intel 5820K Haswell-E Core i7 CPU Unlocked 6 Core Socket 2011-3 Processor
    -Corsair Dominator Platinum 16GB DDR4 2666 MHz
    :idea:
  4. BeauchN
    BeauchN Modder
    5 Apr 2011
    Remember the 5820k only has 28 PCIE lanes, so you'll be no better off regarding SLI than with a Z97 system. You need the 5930k to get the 40 PCIE lanes for multiple GPUs. that immediately adds at least £150 to the cost of the system
  5. rainbowbridge
    26 Apr 2009
