I built my last PC in 2010 and have realised it is time to give it a little upgrade. The trouble I am having is what would be more beneficial for my money. My current PC is: MOBO: MSI 770-C45 CPU: AMD Athlon II X3 440 RAM: 4GB DDR3 Dual GPU: Radeon HD 5770 I'm looking at giving the poor old fellow a bit of upgrade for around £200-£300 any suggestion what would be the best direction to take. I was originally looking at RAM and GPU, but my knowledge is very limited. Any help would be massively appreciated.
Sorry I forgot to say what I'm aiming for. I mainly use it to okay World of Warcraft and Football Manager. So realistically I would like it to play Warcraft at a high setting.
I second Teelz suggestion as well!.. With an SSD you get super fast loading times and I assume smoother in-game loading too, you can't go wrong with Crucial/Samsung/Sandisk/HyperX branded SSDs, however be aware of the newer Kingston V300 models as they have inferior parts and are much slower than their predecessors... As for a new GPU if WoW is optimised for nVidia GPUs then you can't do wrong with a GTX 760 or a little extra for the GTX 960 which both are good for 1080p gaming, if your budget can't stretch that far then a GTX 750Ti should be good albeit maybe with some graphical settings turned down to med-high... Hope this will help you further your upgrade hunt/research ^_^ My 2pence worth!... Sent from my GT-I9300 using Tapatalk
