Displays Upgrade on the cards !!!
Discussion in 'Hardware' started by donok, 16 Sep 2011.
  1. donok
    donok Every Little Helps .....
    16 Feb 2011
    Hey guys
    So I have been using my 3 u2311h dell monitors for Afew months and there pretty great. I paid £495 for them.
    However someone has asked for a build off me and requires 3 screens for work mainly.
    Now i gave a selection to him and he picked the u2311h for size and price. Now I cant get anymore off my usual guy so I'm thinking about selling him mine for £600 with 2 months less warranty and getting a single u2412m. The new 24" dell. Only reason for this is to gain some cash and upgrade to newer tech.
    I wouldn't mind going back to single display at all but Im unsure about the u2412m monitor. Even though i'v read the reviews.
    Just need some guidance really. I would gain £300+ and a new monitor. Plus have been recently annoyed at some games for not supporting 3 displays like dead island. I could use the ££ to get a decent headset and larger ssd
    I'm running
    I5 2500k
    Gtx 580 sli
    120gb vertex 3
  2. donok
    16 Feb 2011
    P.s the guy prefers the older u2311h over the u2312hm. Sonething about the stand quality
  3. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Surely for single screen at ~£600 you could get the u2711. I'm sure 24" would feel a bit small after 3 screens :D
  4. GoodBytes
    20 Jan 2007
    The newer models the U series are inferior to the old ones.
    The panel is lower end (in the case of the U2412M - the U2410 is a true 8-bit panel that can display 10-bit colors (if you have teh requirements (Display Port, compatible GPU, drivers, OS, and software. While the U2412M has much less features, and uses a simple 6-bit panel), it uses white LED, the looks and build quality is less than before. But it's cheaper.
    They are still good screens, but less than before.
  5. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    Ditto. Going from 3 23" screens to 1 24" (even if its a great one) would drive me nuts. Its bad enough when i go from my 27" to a 19" at work, i couldnt survive that at home. Id suggest either a beefy 27" (can still get a pretty good one for that money) or 2 24".
  6. donok
    16 Feb 2011
    The only reason I have picked the u2412m over the u2711 is price and also aspect ratio
