Windows Upgrade or OEM
Discussion in 'Software' started by Spacecowboy92, 3 Feb 2007.
  1. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    Will the OEM version of Vista Home Premium work on my current XP rig, or will I need to buy the Retail version? Thanks
  2. Pookeyhead
    30 Jan 2004
    The OEM version will work on any computer you install it on AFAIK, but the limitations are that if you ever change your mobo, you're knackered. Having said that, I have a OEM version of XP and I changed my mobo twice now... just phoned the Microsoft registration line, explained what I did, and they gave me a new key.
    I think I'll get the retail version next time tho... less hassle in changing hardware etc. If budget is a concern tho... definitely get the OEM version.
  3. Spacecowboy92
    10 Apr 2006
    Alright thanks. Saved me a bit of money. :)
  4. DeX
    DeX Mube Codder
    22 Jul 2002
    Don't forget though that Vista has changed the OEM rules now. You really won't be able to install the OEM version on more than one motherboard. If you ring them up they'll tell you you should have got the Retail version.
    It's definately a tough choice. I think I will make sure I just get a decent future proof-ish motherboard and hopefully not come across any change it after I eventually get a new system.
  5. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Its a wise way to think but how long will the MB last? things fail more often now adays.
  6. mushky
    mushky gimme snails
    24 Mar 2003
    I'm going to wait to hear what people are saying about the replacing motherboards with OEM copies situation. When XP came out I'm sure MS said the same thing but I've never had a problem installing OEM XP on entirely new computers. One quick call to MS and sorted. They just want to make sure that it's not on more than one PC at a time. I know they are saying that they mean it this time but I'll wait to see if they do.
    I mean, what happens with an OEM version if your MB dies? Are you really expected to buy a new OS?
  7. Pegasus
    Pegasus What's a Dremel?
    13 Jul 2005
    About OEM and Vista, take a look at dl.tv and hear what they have to say about OEM, new motherboards and VISTA (it was probably episode 135)
    Anyway, they said that VISTA OEM rules are even more easy and lax than XP rules. So as long as you keep some of the parts from your old setup, like a harddisk, then updating a motherboard should work fine with Vista.
    After two years with my previous motherboard I recently upgraded my motherboard, CPU and Ram and had no problem re-installing XP. I did not even have to call MS activation - could just use the online registration.
  8. Spacecowboy92
    10 Apr 2006
    And will I need to uninstall XP or reformat the hard drive before installation or what?
  9. DeX
    DeX Mube Codder
    22 Jul 2002
    I think you'll need to have XP installed and activated (and probably running) when you stick in your Vista upgrade DVD.
  10. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    But isn't it a normal OEM or Retail version?
    In which case, set your computer to boot from the CD and the setup will guide you through the process. Just make sure that you backup all your important files first! :)
  11. Spacecowboy92
    10 Apr 2006
    I have ordered the OEM version of Home Premium so I will probably do what oasked said.
  12. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    I'm OEM all the way. I don't want to lose my XP serial, I don't want to need to hack around in order to use Upgrade version for clean install. So I choose OEM.
  13. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Vista has been out what, a week? Saying how loose MS are on the licence terms is a tad premature. :rolleyes:
    Actually, the current XP OEM rules are more relaxed than the originals, so that's what seems to have been carried on to Vista - the motherboard is the system, anything else can be upgraded.
    With OEM, you've always been able to replace a faulty motherboard if it's still in guarantee without affecting the OEM license. And AFAIK UK guarantee period is around 5 years, so not much problem there. Thing to ask yourself is, "Am I trying to work a flanker?".
  14. GoodBytes
    20 Jan 2007
    Remember that you might wait an other 3-5 years before a new windows comes out... will upgrade then?! That is the question.
    Side question:
    If I ghost my OS partition with windows installed and activate windows... Will I have to re-activate it again when I use my ghost image?
  15. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Yes. Activation creates or changes a file in the Win folder, so activate then ghost.
  16. GoodBytes
    20 Jan 2007
    Cool, thanks!
  17. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Microsoft has come out and said that the "one motherboard" rule is essentially null and void. Computer savvy folks such as the likes of us are free to purchase the oem at a discounted price and expect the same relative licensing as the retail version.
    If they argue within you upon activation, hardware failure is a good excuse. They won't deny you, guaranteed.
  18. GoodBytes
    20 Jan 2007
    Someone has to try that... really!
  19. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
    If you do a search on google then there are a fair few journalists / bloggers who have tried it already and it does work. But as with anything I would say it's your money and it's not garunteed, and we can't be 100% sure whether Microsoft are just being nice now, until they get nasty in the future...
    But from what I personally have read people have been able to upgrade without a problem.
  20. GoodBytes
    20 Jan 2007
    For business edition, 2 OEM copy is 1$ Canadian less than the retail version.
    Vista business edition RETAIL (full) is 379.00$ Canadian
    Vista business edition OEM (full) is 189.00$ Canadian. (x2 is 378.00$)
    So you still win. :)
    Same applies for all editions
    - Win 9$Can for Home Premium
    - Win 1$Can for Ultimate
    As for upgrade:
    Vista business edition RETAIL (upgrade) is 249.00$ Canadian
    Vista business edition OEM (full (no OEM upgrade exist)) is 189.00$ Canadian. (x2 is 378.00$)
    Here you lose.
    But you must remember that retail full and upgrade has both 32 and 64bit, then OEM you ONLY have 1 version either 32 or 64bit version. (You need to select on of them)
