Cases Upgrade project
Discussion in 'Hardware' started by TobletDanillio, 2 Feb 2012.
  1. TobletDanillio
    TobletDanillio Minimodder
    7 Jan 2012
    edit: I have a Sharkoon T9 with Arctic F12 PW two at the front (intake) 1 at the back (exhaust)
    here is the case on scan
    Last night I installed 3 F12 PWM in to my case and temp have gone down :) only thing is the cables are short so I'm going to make something to make them fit today at work.
    The graphic card temps have come down too :) but I want to cool the graphic card even more.
    The idle temp is not bad but the loaded is still to high for my liking.
    I now have 3 spare fans that came out of my case (stock fans) and I wanted to know if its a good idea to;
    cut a whole in the side of my case and put one of the fans there?
    I will get a filter and something to stop my son putting his hands in the way but I wanted to know if this would help my temp or just mess things up?
    P.s. the fan will be an intake fan on top of the graphic card.
    thanks for the help :thumb:
  2. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Which case are you using? If it's not a well known case than some pictures if your current layout would be useful. :thumb:
  3. TobletDanillio
    7 Jan 2012
    I will at some point take photos and upload them
    edit: here is the case on scan
