Motherboards Upgrade/replacement advice
Discussion in 'Hardware' started by goldstar0011, 2 Nov 2009.
  1. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Howdy
    My motherboard is dead I think so either getting repaired or replaced, been a while since I followed motherboard specs etc so need some advice
    Started with a P5N-E Sli and was very happy, then moved to the P5N32-E Sli Plus, again very happy
    So what next?
    I still what socket 775 and DDR2 sockets, need at least 1 IDE for some HDD's, other than that sockets not so important, play games but not after going crazy, I currently use 2x7800GT's SLI'd, might upgrade next year, playing DoW1, BF2 still and some others.
    Scouted ebay for prices etc, the P5E cropped up and I liked how it can be flashed with the Rampage BIOS but tbh I don't know if that board is a step forwards or backwards or to the side or whatever.
    Can't advise on budget, it more to do with if I get the same happiness with a cheap board then great but if it's etc £20 for major increase then might as well.
    You might notice I seem to only mention ASUS as it's all I know but open to others
    Thanks
  2. goldstar0011
    2 Sep 2007
    54 views, no responses, come on
  3. okenobi
    okenobi What's a Dremel?
    3 Nov 2009
    Gigabyte GA-EP45-UD3R if you plan to upgrade to one GPU.
    Otherwise, Asus P5Q Deluxe.
  4. goldstar0011
    2 Sep 2007
    Good news is mobo is under warranty so sending for repair but have concerns
    LINK
