Graphics Upgrade time from 8800 GTX
Discussion in 'Hardware' started by keir, 27 Aug 2012.
  1. keir
    keir S p i t F i r e
    5 Oct 2003
    ok guys I've spoke about this before, and now my 8800 GTX seems to be on the way out.
    The only thing I seem to struggle with is BF3
    (high/medium settings @ 1920 x 1080) ~35 - 50 FPS
    which is playable most of the time but sometimes causes issues with crashing and drivers going mad.
    I don't see the point in the upgrade unless I can have everything in ultra on BF3.
    I was thinking of a GTX 560 Ti, as this should do the job. But ofcourse I don't want to be in the same boat in a few years whereas the 8800 GTX has done be right for what, 5 years?
    would it be a smart move going for a GTX 660?
    Budget is £300 MAX
    Shirty likes this.
  2. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Wait till the "rush" dies down and prices start to get discounted....
    IMHO
    dunx
    P.S. Latest generation saves power, but more brute force from a new GTX 580 ?
  3. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    if you have the cash I would go for the 660ti m8 .
    The jury still seems out but for 275 ish you can even get the 3gb versions
  4. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
  5. law99
    law99 Custom User Title
    24 Sep 2009
    nvidia 670 or 580 providing you can get one for low enough. £220/230 odd would do it... maybe less second hand, but it doesn't look likely. Prices are way too high still. Always are though with the old top tier cards.
    I've umm-ed and arr-ed over a 7870 in recent times. Similar performance to teh 580 from what I can tell from Anandtech bench in previous times with a fair bit of overclocking potential. Especially if they manage to let you overvolt, as at the moment there is no overvolting on them (last I checked)
    Thinking about it though, you are playing BF3 so you probably want to stick to nvidia
    Edit: Actually the 580 and 660 are close perf wise from what I remember, it may make sense to shell out £260?
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    7950 I'd say
  7. murraynt
    murraynt Modder
    6 Jun 2009
    A second hand 580 GTX or a new 660 GTX Ti would be my choice.
  8. wyx087
    15 Aug 2007
    670 is the one to get. fantastic all round performance, right within your budget.
  9. Elton
    23 Jan 2009
    I'd opt for a used GTX580. They can be had for cheaper than 300 smackers and they perform quite admirably.
    Plus it'll be about 4x the strength.
    Shirty likes this.
  10. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Personally I'd go for one of the premium 660Ti's, like the Asus DirectCU2. As it'll out perform a 580, be in your budget, use less power than a 580, make less noise than a 580 and you'll probably be able to overclock it even further...
    Why go for old tech, when you can have new...
  11. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I agree with the 660 Ti or 670 options - he can get a used GTX 580 for £200 quite easily, but if his budget is up to £300 why should he bother?
  12. mrbungle
    20 Sep 2004
    670 is so much faster than any of the other cards mentioned I wouldnt bother saving the 40 or 50 quid to go for a 580 or a 660.
  13. keir
    5 Oct 2003
    But is it worth the extra power?
    All of those cards will play BF3 without issues.
  14. LennyRhys
    LennyRhys Oink!
    16 May 2011
    It's not about power mate, it's about money - as you said, you're not going to notice much difference in performance between the cards suggested. Bottom line: would you prefer to save money or are you not bothered about spending up to £300?
    If you would rather save money, then obviously a preowned GTX570 or GTX580 is your best bet. :thumb:
  15. mrbungle
    20 Sep 2004
    depends wether you want to play maxed out with say 60-70fps minimum or maxed out 30-40fps minimum.
    Personally for decent BF3 gameplay the higher minimum frames make a wolrd of difference.
  16. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    GTX670 or HD7950 would be where I would be looking.
    The 670 has the "out of the box" performance whilst the HD7950 can be had for less and should overclock to similar performance levels quite easily.
    660TI is only worth it if you can get it for a good price.
  17. Elton
    23 Jan 2009
    The 670 is admittedly an awesome card. But it really depends on how willing you are to spend money. As far as I know, the 660Ti perfroms slightly faster than a 580. But if you can hunt down a bargain, you can usually spot a 580 for 60% of the 660Ti's asking price.
    Mind you I'm cheap.
  18. Nyxzy
    Nyxzy What's a Dremel?
    28 Aug 2012
    I'm in much the same boat,just looking to drag a few more fps out of the old build before big upgrade time. Much I could look at that'd improve on an N280gtx with a large price tag attached?
    Sent from the future!
  19. keir
    5 Oct 2003
    What about this then?
    http://www.overclockers.co.uk/showproduct.php?prodid=GX-033-KF&groupid=701&catid=1914&subcat=2379
    KFA2 GeForce GTX 660TI EX OC 3072MB GDDR5 PCI-Express Graphics Card
    • Specification:-
    • Core Clock: 1006MHz (GK104)
    • Core Boost Clock: 1084MHz
    • Memory: 3072MB GDDR5
    • Memory Clock: 6008MHz (Effective)
    • Memory Interface: 192-Bit
    • Processing Cores: 1344
    • Shader Clock: 2012MHz
    • Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
    • Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
    • SLI Ready (Upto 3-Way SLI Supported)
    • HDCP Capable
    • DirectX 11 Support
    • OpenGL 4.0 Support
    • PhysX Enabled
    • CUDA Enabled
    • 3D Vision Enabled
    • NVIDIA Surround Enabled
    • Lower power consumption (Maximum consumption 170 watts at stock speed)
    • 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
    • TDP: 150W
    • Warranty: 2 Years
    £259.99 inc VAT
  20. keir
    5 Oct 2003
    Guys I'm ready to go with this is it worth getting the 3GB card?
