Other Upgrade Time, Is it Worth it?
Discussion in 'Hardware' started by ComputerKing, 19 May 2012.
  1. ComputerKing
    8 Sep 2006
    Hello Guys, Hope everything is good with all of you...
    I was looking forward to upgrade my system to something newer but I would ask you guys if it worth it or not... I'm not gaming anymore on the system, Mostly Internet And Media stuff ( Playback, And some Light PS )
    So Current is :
    GigaByte Triton 180
    GigaByte EP45-UD3R
    Intel Q9450
    8GB 1066Mhz
    Sapphire 3870X2
    Creative X-FI ExtremeGamer
    Enermax Galaxy DXX 1KW
    Samsung 2220WM
    Thermalright Ultra-120 eXtreme
    7TB Space
    Enermax Clusters 120mm Fans
    I'm Looking for 2 things:
    First, Is To Get a SSD Drive for Windows and programs VS the 1TB Green I have for the system... I think I don't need more than the 120 SSD, But There is a 128GB and a 100GB! Whats the different and which ones is the best for the value and performance on that range...
    Second, Is To change the eXtreme to a Compact Water Cooling system with one 120mm rad, Something like the Kuhler H2O 920... What do you think? is it worth it?
    I don't face any problems with my current but is the efficiency of those old hardware is same as the new hardware now days ? It's like an 2000 7 Series BMW and compared to the new KIA models :)
    Also Will Channing the Sound Card to the ASUS Xonar DX will make a difference ? No Problems with my current
    I'm looking for your advice guys :)
  2. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I moved from a rig very similar to that to my current one and its so much better. I'd go for a 128GB M4, as in the uk they're £89 which is a real bargain. Apart from that, seeing as you're not gaming, I don't really think anything else is worth while, you may save some power by moving to Ivy Bridge but it would take a long time for the saving to offset the outlay.
    I used to run a TRUE 120 and its my favorite tower cooler to this day. I'd personally keep it, as a all in one watercooler wont change much.
  3. Elton
    23 Jan 2009
    To be honest, I'd also change out the 3870X2 if you want to save some energy, that thing probably sucks up quite a bit of juice. Other than that, just sit back and relax, the proposed upgrades are perfect.
    ComputerKing likes this.
  4. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Do you have issues with overheating ? A Corsair H100 might help if you do...
    I agree that your 3870 is an old greedy item, a newer model will be massively less power hungry.
    And a 120/128 GB SSD will be fine, I have an 80 GB item I bought years ago, and I have my i-tunes collection on it as well as W7.
    dunx
  5. TheManicGibbon
    TheManicGibbon I have no idea what's going on
    12 Aug 2009
    I'm in a similar boat - I'd like an Ivy Bridge i7, but I can't really justify it seeing as my current rig performs so well. Similarly to you, I've got a Q6600 and an HD5670, because I don't do much gaming. I recently upgraded to a Crucial M4 64GB and it's fantastic - it's really boosted the machine and definitely a must-have purchase.
    I'd recommend:
    -A 128GB M4. These are just £86 from Scan at the moment and will be a huge boost, especially since you say your system is currently on a WD Green drive - not the best performance for hard drives.
    -A HD6000 series card like a HD6850 or even a 6870 - these are so cheap now (around £100 from Amazon) that it'd be silly to spend more if you're not gaming on a slower 7000 series card (assuming you're sticking with ATI). Perhaps even less. I find my 5670 provides enough power for Eyefinity 3 and some light gaming at 1080p
    Hope this helps!
  6. ComputerKing
    8 Sep 2006
    Yeah An SSD Drive is a must have upgrade for the system i think... the thing about saving power willl not make that much diffrent i think...
    The current system generate alot of HEAT and use alot of power... So that's why I wanted to see what the best i can do...
    The True is the best... But the compact water cooling might be more quiet and don't disturb that much heat as the true !
    thanks alot :)
    I agree About the 3870X2! It's Two 3870 Cards Running at 60C inside the case! And I don't game so it's not that much different, is the 6850 or 6870 is a better option ? i will get more boost and save some noise, heat and power ?
    I think the H100 Will be a killer cooler ?
    Thanks for the replays you guys being very helpful :)
  7. mikeyman198
    mikeyman198 Lets pretend this is hilarious.
    12 May 2011
    The 6870 is better than the 6850, and about £20 more. The H100 is a great cooler, but a bit overkill and with the stock fans can be very noisy. The Gelid Tranquillo would be a better option, and a hell of a lot cheaper :thumb:
  8. ComputerKing
    8 Sep 2006
    after research... What do you think of...
    1) ANTEC KÜHLER H2O 620 for 85$ Upgrade over my True With Enermax Cluster Fan ? because my cpu idl at ( 2 first cores = 51 , 2 last cores = 41 , AVG for all ) And While Gaming or Encoding IT hit 60+ ( Fans running at 1300RPM )
    2) An 120GB SSD Card But Which ? some options i found in the local market !
    1- Kingston HyperX 120GB (SH100S3/120G) For 200$
    2- Corsair Force Series 3 GT 120GB For 200$
    3- Adata XPG SX900 128GB For 190$
    4- Intel 330 Series Maple Crest 120GB For 175$
    Any Good ? Should I look To something better ?
    3) The Graphic Card I don't know... Lately I played Max Payne 3 with auto settings was taking around 750MB of the memory i think and was no lagging and not that bad effects ! the problem It was too HOT! reached 90s with fan on 40... I had to speed fan to 85 - 95 and Turn the game volume too high to be able to game :( I dunno what would be a worth replace to this card :( or should I spend more on cooling or the new direct x and shader thingy and win 8 will not support this card :(
    4) THE PSU is over kill and perfect but lately I noticed that fan is running fast and make noise :D any fix to that ? other than cleaning ?
    Last Thing...
    Here a snap of my idle temps :( the room temp is around 24-25 .... the noise i think is 45 - 55 decibel and that is not comfortable while sleeping :( any solution to that ? because i leave the system running all the time :( while in load those temps hit high levels as i said before :(
  9. Bloody_Pete
    11 Aug 2008
    I'd say the kingston or a Crucial M4 personally.
    I'd suggest you get some more powerful fans for your TRUE, if they don't help them you can use them on your Kuhler for increased performance. I personally used a pair of 1850 rpm Gentle Typhoons on my TRUE and it was perfect.
    Maybe a 560Ti, as they're fairly cheap now, or wait and see what the 660 is like, as rumors suggest it'll be launched over the next month or so...
    Give the PSU a clean, it should still be perfectly good. You could replace the fan, but in a 1KW PSU it'd be a risk to your health...
  10. ComputerKing
    8 Sep 2006
    Thanks for your replay sir :rock:
    I will look for a Crucial M4 If I'm not lucky then I think I will go for the Kingston as you recommended
    The problem those Enermax Cluster 120mm Fans Running on 1350RPM And They Are Silent... I got one on the True Then Another On the back of the case And another 2 on the front as intake :( and i still get this temps :(
    I will wait on the GPU or look for a used card deal :)
    the PSU is perfectly good after running 24/7 those years :) but the fan speed rise on the load :( duuno if because it gets hot air from inside the case or what :(
    This is a pic to understand what i'm talking about :(
  11. Bloody_Pete
    11 Aug 2008
    OH DEAR LORD, THE WIRES!
    I'd suggest upgrading your case...
  12. Guest-16
    Guest-16 Guest
    Agree with this very much. The Enermax DXX's weren't known for being the quietest out there and you can get semi-passive PSUs that kill all noise now. Might be worth an upgrade, if you care. Modular would benefit you too! Power-quality-wise though the Enermax is fine. I would NOT change the fan.
    Agree the TRUE is a great cooler. No need to upgrade, unless it's not got LGA1155/6 compatibility.
    560 Tis are cheap, but maybe wait for 660 ;) Shouldn't be long. Depends how urgently you need to update.
    The rest have been covered: SSD and case change is your main focus imo.
  13. ComputerKing
    8 Sep 2006
    Oh Thanks Bro for your advise :) I really miss old days :) you always came to help :)
    Okay :D Suggest me a case and a PSU :rock: And Chaning the VGA to 560 / 660 Will Use a Lower PSU ?
    What do you suggest then :( I want small case :(
  14. murraynt
    murraynt Modder
    6 Jun 2009
    Fractal R3?
  15. ComputerKing
    8 Sep 2006
    What about Cooler Master Silencio 550... I Don't know about Fractal if i can get it locally :jawdrop: But It's Awesome!
  16. ComputerKing
    8 Sep 2006
    Looking at futuremark database I found out that :
    1- NVIDIA GeForce GTX 560 Ti : Takes 4640 : Price 210$
    2- NVIDIA GeForce GTX 480 : Takes 5820 : Price 210$
    3- AMD Radeon HD 6950 : Takes 5200 : Price 220$
    4- AMD Radeon HD 7850 : Takes 5780 : Price 250$
    My Radeon HD 3870 X2 : Takes 2460
    What do you think ?
    Lol Checking the CPU
    MY Intel Core 2 Quad Q9450 : Takes 3350
    The Intel Core i5-2500K : Takes 5790 : Price 207$
    Huge difference !!!! What do you think ?
    About SSD Drive !!!!!
    OCZ Vertex 3 120GB : Takes 5270 : Price 110$
    Corsair Force GT 120 GB : Takes 5070 : Price 130$
    Crucial 128 GB m4 : Takes 4930 : Price 121$
  17. murraynt
    murraynt Modder
    6 Jun 2009
    Great case! What site are you buying from?
    I would go with 560 ti. Maybe a giagabyte or Asus one with the larger heatsinks.
    CPU depends on how much cash you want to spend.
    The m4 would be my pick from SSD's but only because I own one and i have never had a problem with it.
  18. ComputerKing
    8 Sep 2006
    From A Local Shop in my city :) That's why I said that case they have it for arround 110 $ I think !
    yeah about graphics i will look again but i think the 560 ti as you said is the best deal now...
    cpu it's not how much cash :) it's like i think my quad do whatever i want it to do.. but that i5 is way faster ( scores ) and less heat, power... I will look up again because this means i have to change everything :)
    then I'm going for the M4 :rock: and i will pick up that case in the next days and post the updates and tell you guys what is going on ;)
    thanks all for the help :clap:
  19. Bloody_Pete
    11 Aug 2008
    Yeh, leave to cooler and CPU for now. Just do case GPU and SSD, and go from there :)
  20. Elton
    23 Jan 2009
    For a cheaper option go with a 7770. If you're not doing much gaming. Why not?
