Graphics Upgrade to HD5770 worth it?
Discussion in 'Hardware' started by penryn 2 hertz, 10 Jun 2010.
  1. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    hi i would like to know if it is werth the upgrade from my hd 4850 1gb to a new hd 5770 1gb??? im running a phenom ii x2 550 be @3.6ghz with a gigabyte 770 chipset mobo with 4gb of ddr2 800mz kingston hyperx ram and a corsair tx 650w psu with windows 7 32bit im gameing @720p on my 26 inch lcd tv @ 60hz .
  2. penryn 2 hertz
    10 Jun 2010
    Upgrade...?
    Hi my specs are my cpu is pnenom ii x2 550 be @3.6ghz my ram is kingston hyperx 4gb ddr2 6400 my current video card is hd 4850 1gb my psu is corsair tx 650w my chipset is 770 I was thinking of an upgrade to a hd 5770 1gb I was thinking is it werth the upgrade from my hd 4850??? I game at 720p @ 60 hz on my 26inch lcd...
  3. Marine-RX179
    Marine-RX179 What's a Dremel?
    24 May 2010
    Not really. Moving from 4850 to 5770 is like move from 4850 to a 4870, but with with dx11 and lower power consumption. Your 4850 is more than fast enough for 720p. Don't really think you need to upgrade graphic card unless you are upgrading your montior/display to higher res.
  4. adam_bagpuss
    24 Apr 2009
    +1 no need to upgrade if your gaming at a low res like that.
    the 4850 will handle that no problem
  5. Domestic_ginger
    Domestic_ginger What's a Dremel?
    16 Mar 2010
    Have you treid unlocking your chip? With the new bios sets you can relock an unlocked core giving the possibilty of a tri. Might be worth a free upgrade.
  6. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    A 5770 isn't that much more powerful but why are you gaming at 1280x720 on a 26" monitor? Unless it is a 26" TV?
  7. Iskador
    Iskador What's a Dremel?
    21 Feb 2010
    Probably not. I don't think you'd see much difference.
  8. adam_bagpuss
    24 Apr 2009
    why the hell you made 2 threads for the same thing ?
  9. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    It'll be a 'HD Ready' TV. Depends how much you want Dx11, but it'll be worth saving for a 5850 really.
  10. Zaim
    Zaim What's a Dremel?
    18 May 2010
    deleted
  11. Blanx3_Bytex
    Blanx3_Bytex What's a Dremel?
    3 Feb 2010
    As far as the reviews show the Standard 5770 gives similar performance to the 4870 but im not sure the performance gains would be especially worth it in most games.
    I wouldnt think it was especially worth it my self but it probably depends if you want to try dx11 or not.
    Out of interest what games is the 4850 struggling in?
  12. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    You want at least a 5850 to see any real difference tbh.
    I'm surprised that 4850's struggling much at 720p though..
  13. bagman
    bagman Minimodder
    18 Apr 2009
    i am not supprised that his 4850 is struggaling as 720p is 1680x1080 which a 260 gtx is more suitted to than a 4850
    but for you i recomend a 5850 or if you don't have the money get a second hand 260 gtx
  14. Yadda
    Yadda Minimodder
    25 Jul 2003
    720p is 1280*720.
  15. adam_bagpuss
    24 Apr 2009
    wrong my friend very wrong.
    720p or 1280x720 = 921600 pixels
    1680x1050 = 1,764000 pixels
    thats almost double the pixels so would require a card thats alot more powerful if you can only just play on 720p
    and a 4850 isnt that much slower than a 260 it is but it would hardly be an upgrade from a 4850 to a 260
  16. bagman
    bagman Minimodder
    18 Apr 2009
    damn quite a big difference then in resolution
    but the 260 is considerably quicker than 4850 just look at some bench marks nearly 20 frames difference in some games
  17. EvilMerc
    EvilMerc Minimodder
    1 Feb 2010
    Thing is you'd be paying money for a card that's of the same generation so it wouldn't be a massive improvement. Yes, it is a better card, there's no denying that, but it isn't a worthwhile investment.
    Another problem with it is the increased power consumption and heat output, the 5850 comes out on top for both of those while delivering better performance.
    I'm still surprised that there are performance issues with a 4850 with a 720p display. I managed Crysis on high with a 4670 and only AMD Athlon X2 5200+ at 1280x1024 so a 4850 and a Phenom II should be fine!
  18. Coltch
    Coltch Minimodder
    3 Jul 2009
    My 512MB 4850 happily chugs along in games @ 1920 x 1080 (GRID, ME2, COD4).
    If I was to upgrade my card it would be for a HD5850 minimum.
    The only games that punish my card are Crysis and GTA IV
  19. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Whilst this is true at 1280x720 a HD4850 will be humming along quite nicely.
    As an example a GTX260 will offer higher framerates but the perceptible difference when compared to the HD4850 will be non-existant.
  20. Gothic-Yoshi
    Gothic-Yoshi The Matrix has you!!!
    2 Jun 2010
    U wouldnt really need to upgrade but the HD5770 is a very good Graphics Card for its price.
