Build Advice Upgrading Core Components
Discussion in 'Hardware' started by The Razman, 25 Jul 2013.
  1. The Razman
    The Razman What's a Dremel?
    8 Dec 2009
    Just wanted to check with you guys if this was a good idea for an upgrade from my i5-750. It's a few years old and starting to get problems, so I wanted to upgrade to this:
    CPU: Intel Core i5 3570K
    Mobo: Gigabyte GA-Z77-D3H
    RAM: 8GB Corsair DDR3, PC3-17066 (2133), 11-11-11-27
    Putting this together with the GTX 560Ti which is already in my current machine and is newer than the CPU and Mobo. Machine is mainly used for gaming, with a bit of video-editing here and there. Also planning on overclocking with the new system, something I didn't do before. Is this a good idea for an upgrade or is there something with better bang for buck I should be considering?
    I don't have a set budget for this, but I'd rather not spend more than £180-200 for the CPU.
    Thanks guys.
  2. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    Hey Raz,
    If I were you, I'd go for the newer Haswell parts (the i5 4570k). This will probably be the same price as the component you're looking at, just more powerful as it's current generation. Obviously you'll need to change the mobo to suit this, and check that your PSU is Haswell compatible!
    Regards, Fuus
  3. The Razman
    8 Dec 2009
  4. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Even better, try and pick up an i5 2500k to go with that Z77-G3H because the 3570k runs as hot as a volcano. The market price is about £100 for a 2500k. If you get a good chip and overclock it to 5GHz then any 'performance boost' will be negliable.
  5. The Razman
    8 Dec 2009
    I haven't seen an i5-2500k for less than £180 ...?
  6. djzic
    djzic Bokehlicious!
    8 Nov 2010
    I meant second hand, sorry it was unclear.
