Peripherals Upgrading laptop wi-fi, antenna question
Discussion in 'Hardware' started by Splynncryth, 21 Aug 2010.
  1. Splynncryth
    Splynncryth 0x665E3FF6,0x46CC,...
    31 Dec 2002
    The 2.4GHz spectrum at my apartment is overcrowded so I picked up a dial band router. I need to upgrade on of my laptops so it can use the 5GHz network. Swapping out the mini PCI card should be easy enough, but I'm a bit worried about the old antennas and how they will handle 5GHz. The frequency is a little more than double 2.4GHz so I don't know how well the card will handle the less than perfect match.
