Upgrading my computer
Discussion in 'Hardware' started by zach1288, 12 Jun 2006.
  1. zach1288
    zach1288 What's a Dremel?
    7 Feb 2005
    You can see my current system in my sig. I want to upgrade it this summer with a new motherboard, cpu, memory, video card, PSU, HDD(SATA) and maybe a new case
    Now i want to get an AMD 64 cpu(dual core) with the new AM2 socket and im not sure what motherboard i should choose. What would you suggest for a motherboard? Also if you want to suggest a CPU, memory, video card, etc go right ahead
    Also is DDR2 avalible on these motherboards yet?
    This system will be for gaming/workstation i want it to be pretty powerful but dont want to spend over 1k if thats possible
    Thanks,
    Zach
  2. bubsterboo
    bubsterboo What's a Dremel?
    24 Jan 2006
    DDR2 works only with the new am2 processors
  3. zach1288
    7 Feb 2005
    Read above^ Thats what i want.
  4. geek1017
    geek1017 What's a Dremel?
    6 Aug 2002
    Maybe he didn't understand your question or you didn't understand his answer.
    To sum up: yes, AM2 motherboards use DDR2. Yes, plenty of DDR2 is available.
    As for suggestions for your system, hit up Newegg.com and read reviews.
    A 1k budget is pushing it for a complete new system I'd think but it is possible.
    personally, I'd not bother with AM2 yet. Go for a Pentium D 805 and wait for conroe.
  5. zach1288
    7 Feb 2005
    Im an AMD guy.
  6. geek1017
    6 Aug 2002
    Normally I'd be an AMD guy as well. My current home rig is a XP2500+.
    The cheapest AM2 X2 is the 4200+ 2.2GHz @ $370 + shipping.
    a decent motherboard, the ASUS M2N-SLI Deluxe is about $150 + shipping
    You don't say how much RAM you want, but a good 1GB kit is G.Skill @ $130
    so a base system cost of $650 and none of this is excessive.
    You could get away with one stick of Ram for a bit less or you could find a cheaper ECS motherboard perhaps.
    True, it would thrash either of our current systems, but the upcoming Intel offerings seem to be getting much better reviews for price/performance.
    just my 2 cents, but Conroe looks to be taking the crown away from AMD for performance, price, and overclockability.
    AMD had better have an answer for this Intel barrage before x-mas.
  7. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    AM2 is simply AMD64 with DDR2. Right now It's still the best solution. The problem is wether or not you trust conroe beeing better or not. Both the Prescott and the newer model (not sure what it's called) havent been able to beet it.
  8. zach1288
    7 Feb 2005
    People on other forums said not to get AM2 and just get a 939 board because DDR2 and AM2 dont always play nice together.
