i want to upgrade my pc, at the moment i got a AMD sempron 2800+ geforce fx 5500 1gb ram pc3200 asrock k7vt4a pro motherboard i want to go dual core but i dont want to spend a fortune. what is the best one to go for on a budget but has still got enough power? do you think i should get a new graphics card aswell? whats the new mod cons to have nower days? i use it for playing games mostly but i want the graphics set to full but run at a decent frame rate. cheers
yeah probably, what would you do? i read something somewhere and it said blow your budget on the graphics card.
£200 too £300 i dont need ram or a new hard drive and stuff just motherboard, cpu and graphics card. i was looking at thoses geforce cards with sli, how good is that. and those motherboards with the cooling pipes on, they look sound.
I would say that you should go with a SKT 939 3800+ dual-core + an ASUS A8N-series SLI board + something from a 7600GT to a 7950 GT. P.S. What kind of PSU do you have?
Doesn't really work if he's only got £300 to spend. If you can stoop to 2nd hand kit, you should be able to get that lot for about £300, but if you can only buy new parts, you'll probably end up with a 7600GS and similar to the above.
You can hit that budget no problem Opteron 146 Retail ebuyer/scan £59 AMD Athlon 64 (ADA4200BVBOX) X2 4200+ socket 939 Dual Core 2.2ghz 512kb and 512kb Cache - £133 ebuyer MSI K8N Neo4-F SKT939 nForce4 chipset Dual DDR400 PCI-E ATX - £43 ebuyer Asus A8N-SLI SE Socket 939 Nvidia NF4 SLI ATX - Sound, Giga Lan USB 2.0 1000MHz FSB SATA - £57 ebuyer EPoX EP-9NPA3 SLI, nForce4 SLI, Socket 939, ATX, S-ATA2, GbLAN, DDR, PCI-Ex16 - Komplett £60 Graphics, shop around for quickness I went to ebuyer Inno3D GeForce 7600GT 256MB TV Out DVI Core 560MHz Memory 700MHz PCI-E - £90 You can pick up a 7900gs for aound £110./115 X1900GT 256 around £130 X1900XT 256MB around £163 or for pure bang for buck a 7300gt 8 pipes ddr3 256mb for £68 --added XpertVision GeForce 7600GT 256MB DDR3 £82.24 microdirect I would also think about a new psu, unless you have already got a decent one edit Been having a look around x2 3800 pretty hard to find
RTT I think Krikkit has hit the nail on the head. Save up some more pennies, £500 would get you an okay system as a new PSU might well be needed too
thanks for the help. i think im gunna just get a good part every month. im gunna go for the 3800+ cpu, whats the best socket motherboard to go for. the am2
