Storage Upgrading to larger disks in RAID 5 array, need some advice
Discussion in 'Hardware' started by Bungletron, 1 Nov 2013.
  1. Bungletron
    Bungletron Well-Known Member
    25 May 2010
    Hello
    I have 6TB RAID 5 array managed by a High Point RocketRaid 2680 card that currently uses 4 x 2TB disks. I was thinking I could upgrade all 4 disks to 3TB disks for 9TB total storage.
    I was thinking to upgrade the disks by degrading the array 1 disk at a time, adding each new 3TB disk and then rebuilding each time? Then after all 4 disks are upgraded and the array is rebuilt increase the partition size from 6TB to 9TB? I have the files backed up but want to avoid building a new array from scratch since it means configuring the network share all over again and it also takes ages.
    What do you reckon, is this reasonable or have I missed something, is this likely to have issues? I am confident one of you lot has the answer, cheers! :thumb:
  2. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I'm pretty sure if you took a 2tb disk out of an array, put a 3tb disk back in and rebuilt it, it would treat it as a 2tb disk. But I might be wrong.
  3. saspro
    saspro IT monkey
    23 Apr 2009
    I'd say you'd end up with spare space on the drives to create another array on.
    It's generally only things like SAN's & some NAS's that can expand
  4. droyden
    droyden New Member
    6 Sep 2011
    Yep new array and migrate, degrading your array will potentially cause pain.
  5. asura
    asura jack of all trades
    22 Apr 2009
    ZFS can do that... but I have no idea about a conventional RAID.
  6. droyden
    droyden New Member
    6 Sep 2011
    If the raid card supports shrinking the existing array then that might be an option.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    RAID5 does not support expanding an array, if you swap the disks for larger disks the array will not expand.
    Unless you're using another RAID type your only option is migrating the data off the array, destroying the array and creating a new array with the larger disks is the only option.
  8. droyden
    droyden New Member
    6 Sep 2011
    OK I wasn't sure, you can resize a linux mdadm software raid online.
  9. Bungletron
    25 May 2010
    will make a new array I think then, cheers guys!
  10. adrock
    adrock Caninus Nervous Rex
    5 Dec 2006
    if you're running LVM on top of your existing raid 5 then I can think of ways of doing it without building the new array and migrating data, but i'd probably still choose to do the latter.
  11. Atomic
    Atomic Gerwaff
    6 May 2002
    Yeah software RAID is a different kettle of fish to hardware RAID and often provides extra features outside the traditional spec of RAID, like being able to expand an array and change the RAID type.
