UPS? Battery backup...
Discussion in 'Hardware' started by hagatha, 16 Nov 2007.
  1. hagatha
    hagatha No Guts? No Glory!
    3 Aug 2007
    Hey all,
    Our area has been experiencing power outages pretty regularly... I have way to much invested in this system to take a chance on the power blinking and screwing something up.
    I know only what I've read in a few threads and web sites... I can't really find and reference to what size is really needed or a particular bard that is better than the other...
    Any input, opinions??
    hagatha
  2. capnPedro
    11 Apr 2007
    Anything around the 1200VA mark by a good manufacturer (Belkin et al) should be the the sort of thing you're looking to buy.
    Set aside, around $150 for a quality unit.
  3. Glider
    Glider /dev/null
    2 Aug 2005
    There's only 1 brand for UPSes IMHO, APC
    http://www.apc.com/index.cfm?ISOCountryCode=us
    The UPS selector gives:
    Best Price: APC Back-UPS ES 8 Outlet 550VA 120V (Price: $59.99)
    Best Value: APC BACK-UPS ES 8 Outlet 650VA 120V (Price: $79.99)
    Best Performance: APC Back-UPS ES USB 750VA w/TEL & COAX 120V (Price: $99.99)
  4. ralph.pickering
    ralph.pickering New Member
    6 Apr 2005
    Apart from APC, the MGE Evolution UPSes are pretty good. I've had a 2200VA one running for 3 years now with no glitches, and a fairly high load (6 dual xeon servers). No extended outages in that period, but it's coped with a more than a few brown-outs and spikes.
  5. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Don't forget Tripp Lite.
    I personally have an APC SmartUPS 1000XL (675w, 1000va).
  6. n0ferz
    n0ferz New Member
    30 Sep 2007
    There reason why my computer shut downs when we have an electricity problem is because my UPS is too weak to handle it?
    Sometimes my computer stays running but sometimes it just shutdown :waah:.
    I dont wanna risk this new 3 weeks old gaming rig :nono:
  7. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    if you do get a UPS it might be worth looking at beefing up your surge protection as well, some of the controllers in them can be pretty suseptable to a transient surge.
  8. Computer Gremlin
    Computer Gremlin New Member
    11 Sep 2006
    I use a APC Back-UPS XS 1500VA which can hold a 860 watt draw for 4.5 minutes. The newer RS model has a RJ-45 to protect your internet connection. Look for boost and trim functions on the UPS. They either increase or decrease the voltage from the socket by to your computer without using the battery. By using a little bit of the battery and charging it in the background to compensate little changes in the line voltage prevent frequent switching to the battery as the only source of energy.
    This prevents unneeded wear on the battery and extends the time between getting them replaced. The RS model costs over two hundred dollars but considering the value of all your other hardware it acts as an insurance policy for the computer.
  9. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    what you want is a ups that supplies power from the battry constantly instead of only switching to battry when the mains dies. That way the switch over to battry power is seemless and your mains is filtered by the battry. On the down side your net power consumption goes up.
  10. Almightyrastus
    21 Mar 2002
    This is why you ensure that you get decent surge protectors with thermally protected MOVs inside them. the vast majority of ones bought in electronics stores are more likely to have the cheaper, unprotected ones in them and as a result they are more likely to overheat.
