upside down hard drive?
Discussion in 'Hardware' started by keir, 4 Jul 2005.
  1. keir
    keir S p i t F i r e
    5 Oct 2003
    Will mounting a hdd upside down damage it, in anyway.
    I will just be easier if I mount it this way, for cables and stuff :)
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Nah, no problems there mate. Unless mabye it's really old, but I can't see it damageing anything made in the last 5 years.
  3. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    Anything with fluid bearings should be okay, so just about anything made in the last 4 years or so. Just don't move it upside down when it's spinning
  4. Krikkit
    21 Jan 2003
    Why not? *tips HD's upside down* There's nothing wrong with it!
    Bashing it is the thing to avoid :p
  5. keir
    5 Oct 2003
    mint, cheers dudes.
    I'll give it a go tomorrow
  6. FIBRE+
    FIBRE+ Minimodder
    27 Feb 2005
    you can mount it anyway so long as its flat/level, if the width of a platter is at an odd angle it wont do it much good.
  7. Imotox
    Imotox What's a Dremel?
    12 Jul 2005
    I have 1 sitting Vertiacal and work works fine :thumb:
  8. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    the platters can be at any angle they like, so long as they are steady, and you dont try to move the drive when its spinning.
