Graphics URGENT:Counterfeit?
Discussion in 'Hardware' started by Ryu_ookami, 28 Oct 2018.
  1. adidan
    25 Mar 2009
    I only glanced at the thread as was in a rush - thought it best to post even though I thought there would be a reason, just in case.
    Not a fan of people wasting money, but yeah, should really only look when I have time :)
  2. SuperHans123
    SuperHans123 Minimodder
    27 Dec 2013
    Just installed one of these in my system yesterday. Pisses on a 1050ti
    Even the 4GB version eats it.
  3. Vault-Tec
    30 Aug 2015
    Yup close to the 1060.
  4. TheMadDutchDude
    23 Aug 2013
    I too failed to read it properly....:D
  5. Alsomething
    Alsomething What's a Dremel?
    22 Apr 2009
    You need to remove the TIM to read whats on the chip and so you can re-apply new TIM to refit the heatsink. If you don't clean it and apply new TIM you will mostly likely get over heating issues. What device is reporting in device manager? Which drivers did you install manually or do you let windows do it automatically?
  6. TheMadDutchDude
    23 Aug 2013
    Already confirmed to be a fake 1050 Ti and likely just a 550 Ti in its place, fella. :D
    bawjaws likes this.
  7. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    From most of the customer reviews on amazon not the greatest place I know but I've normally gone with Nvidia so thats what the GF brought while I was hMMMING AND AHHHING
    I paid 102.98 for 2 of them, yes I know, well I know now, especially as I've just brought 2 proper ones and they cost me 343.98 for the 2
    seeing as the new ones turning up today I decided to try and benchmark the fake. fake mark.jpg
  8. SuperHans123
    27 Dec 2013
    You know the old adage, 'If it looks too good to be true, it probably is'
  9. veato
    veato I should be working
    15 Jan 2010
    There are numerous listings right now for these suspiciously cheap 1050TIs. They really need reporting.
  10. TheMadDutchDude
    23 Aug 2013
    There are hundreds of them here too. Anything from 1050s right through the 1080 lines.
  11. yuusou
    yuusou Multimodder
    5 Nov 2006
    Flash a 550ti bios back onto it and use it for a htpc.
  12. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    I heard the bit-tech saying was " If it looks too good to be true, GaryP will do you out of 50p ".
    adidan, alfizzle, Arboreal and 2 others like this.
  13. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Only accept Brexit 50p's now, unfortunately...
  14. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Just to confuse matters further, Ebay is being flooded with ex-cyber cafe GTX 1050 2GB, 1050ti 3GB and 1050ti 4GB cards from China, where there are a bunch of region exclusive models. Those cards 'are' genuine but are all so thoroughly thrashed they maye as well be fake.
  15. wolfticket
    19 Apr 2008
    I'm going to buy one to go with my £9 - 128GB Micro SD card: https://www.amazon.co.uk/SanCard-Micro-Class6-MicroSDHC-Smartphone-128gb/dp/B0787GPY69/
    It must be real since it comes from a reputable brand like SanCard...
    It is bad how easily obvious fakes are sold on reputable sites. To an extent it doesn't matter to most people here, because you can take a punt and check it out for yourself. If (when) it is fake you might even get a free odd bit of tech to play with, on on very rare occasions a silly bargain. However they must be making money somewhere along the line by screwing people, and they're using Amazon/eBay's sense of familiarity and security (ymmv) to help them do it.
    Sometimes I even see obviously fake cards turn up on Amazon Warehouse Deals, which means they've probably be sent back for obvious reasons and now Amazon are effectively reselling them themselves clearly without actually checking them or dealing with the issue.
  16. Ryu_ookami
    11 Mar 2004
    well after being told by paypal to send the olds ones back I rang them and got though to an advisor who as it turns out is a gamer, I explained the issue with the cards being counterfeit and the cost of sending them back and now I've got a full refund and I don't have to send them back. :) so its a win for me :)
    Sentinel-R1 likes this.
  17. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    If they've refunded you without wanting to investigate, it must be quite a common thing - as pointed out above.
    Glad you've recovered your dosh and are up and running.
  18. Ryu_ookami
    11 Mar 2004
    okay so the counterfeit cards saga continues for curiosity's sake I've removed the thermal paste (what there was of it) and cleaned the chip so I can see whats written on it which is as follows (its in caps because that's how it appears on the card)
    The first card
    NVIDIA
    12C18163 1202A1
    s taiwan
    PFN614.MO1
    GF116-400-A1
    The second card
    NVIDIA
    12C78008 1226A1
    S TAIWAN
    PHY1255.MO1
    GF116-400-A1
    Problem being I have no idea how you use those numbers to identify the cards.
    Edit:
    Okay googling the last row of numbers returns that both cards are
    Nvidia geforce 550 ti's.
  19. yuusou
    yuusou Multimodder
    5 Nov 2006
    Flash them with legitimate 550ti bios and re-purpose them.
    adidan likes this.
  20. Goatee
    Goatee Multimodder
    19 Apr 2015
    What do I win? :)
    adidan likes this.
