Graphics URGENT HELP REQUIRED - no display
Discussion in 'Hardware' started by donok, 3 May 2014.
  1. donok
    donok Every Little Helps .....
    16 Feb 2011
    my system has gone down. it starts up but cuts out then starts again. my keyboard n mouse are not powering up and the pc isnt displaying anything on monitor. via VGA. all my uni work is backed up but i have an exams starting next week and really need access to it. please help me fix it.
    specs
    intel g2020
    msi b75-p45 mobo
    500gb hdd
    corsair cx430
    4gb corsair ddr3
    keyboard lights come on when starting pc but when pc cuts out and starts again no keyboard lights.
  2. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    First things is do,
    Remove all ram and try each one as singles.
    Try another psu.
    Ensure the heat sink is seated correctly.
    donok likes this.
  3. donok
    16 Feb 2011
    each ram stick in and out. Tried cx600 i got afew days ago
    and checked heatsink.
    exactly the same situation. the pc boots for 5 seconds then dies for around 10 seconds and the boots up with no display or keyboard mouse.
    pc was working fine afew hours ago.
  4. ARM
    ARM Minimodder
    15 Sep 2004
    Are you overclocking your system ? If yes then return to default setting.
    donok likes this.
  5. donok
    16 Feb 2011
    no overclock at all. no display whatsoever so no bios to change settings
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    You have reset the bios right?
    donok likes this.
  7. donok
    16 Feb 2011
    remove battery ?
  8. donok
    16 Feb 2011
    bios reset same situation. boot then cut out then boot with no display
  9. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    Boot the system out of the case?
    donok likes this.
  10. loftie
    loftie Modder
    14 Feb 2009
    Dying MB?
    Edit: Probably a bit premature actually, I assumed it was a P45 board and it's not. Could still be an option.
    donok likes this.
  11. donok
    16 Feb 2011
    so i pulled the system appart and booted out of case. just using the power button hooked up from case. same problem occured.
    iv got a asus p8p67 m pro in currently transplanting into.
    so i swapped mobos and then added a 280x gpu as theirs no onboard video out on p67. and it boots up and works but drivers are everywhere
    is a fresh install of windows the only option ?
  12. GeorgeK
    18 Sep 2010
    To test it it's the OS install that's to blame you could try booting from a live CD (ubuntu etc) - but that's only feasible if you can get on someone else's computer to burn a disc. Are you saying that it works with a different GPU? If so then surely it's the GPU rather than another issue...
    Also - I appreciate that this is a stressful time but could you try to use the edit button rather than triple post... I've merged your previous posts.
    donok likes this.
  13. mrbungle
    20 Sep 2004
    Just reinstall the drivers, intel systems are pretty good at being swapped around!
    donok likes this.
  14. donok
    16 Feb 2011
    I'd like to thank everyone you guys are life savers. pc is working with afew issues but nothing major
    dual dvi cable from 280x to u2711 is only putting up 1280x1440. at 2560x1440 all text is unreadable so iv dropped down to 1920x1200 for now and Iv ordered a displayport cable to resolve the issue
    asus mobo onboard sound is acting up. reinstalled drivers several times but to no avail. my headset outputs sound fine but my speakers are only outputting extremely low volume. a google search revealed its a problem with some asus p67 mobos. I will order a asus xonar if I cant find a solution.
    thanks again guys
  15. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    look for blown/leaky caps on the board, as it sounds like a board issue to me. the crosses on top of the caps should not be bulging at all and should be totally flat, you may see a rusty colour on top of them this indicates they are leaking, also not good.
  16. mrbungle
    20 Sep 2004
    Id put it down to low end MSI junk :p
  17. donok
    16 Feb 2011
    I think iv got 2 years warranty on the mobo and it was purchased from scan in august 2012
  18. loftie
    loftie Modder
    14 Feb 2009
    Glad you got it sorted. I think modd recently bought an msi board where the quality control obviously was forgotten. Shame really.
