Displays URGENT monitor streaks all white light from left to right, close to unusable.
Discussion in 'Tech Support' started by PortalBen, 13 Dec 2009.
  1. PortalBen
    PortalBen Minimodder
    22 Nov 2009
    Thanks for reading this, I really need help.
    My display streaks all white colours from left to right, faded out. It has been bugging me for weeks and though I asked for help on a similar problem before nobody gave me any help at all.
    The monitor is close to unusable now and I rally don't want to have to for out for a new monitor for what I am sure is a simple problem.
    I have a 19inch Hannspree widescreen monitor. I have tried fiddling with all the settings on the monitor's OSD. I have tried uninstalling and reinstalling my graphics card drivers. I have tried uninstalling and reinstalling my monitor drivers. Nothing has worked.
    If you have any ideas, please, please, please take five minutes to try and help me.
    Thanks alot
    Ben
  2. Golygus
    Golygus What's a Dremel?
    9 Oct 2003
    3 things.
    1 have you tried it on another pc
    2 have you tried a different monitor
    3 how old is it?
  3. PortalBen
    22 Nov 2009
    I've tried a different monitor and that seemed to work fine.
    Unfortunately, I have no spare pc to test it with atm :(
    It is 16 months old and worked brilliantly up until I took it to a LAN party 4 weeks ago today. Since then, it hasn't worked properly.
  4. PortalBen
    22 Nov 2009
    Also, whenever I cut power to the monitor and then turn it back on again the probelm gets alot better but is still slightly noticable.
  5. nightblade628
    nightblade628 Minimodder
    10 Dec 2009
    I'm no monitor technician but if another monitor works on your PC fine then at least you know it's nothing to do with your PC. If I were you I'd call up the manufacturers and tell them the problem, likelyhood is they would have heard of the problem happening before by at least someone else and can advise you. If tinkering with the monitor settings doesn't work and there's nothing left on your warranty my guess would be you either fork out for a repair or buy a new one. You could also try googling the problem.
    I realise you said you wouldn't like to buy a new one so maybe a repair won't be too costly.
    I wouldn't like to advise opening it up and checking inside, it MIGHT be something that's loose but that's something better discussed with tech support.
  6. Golygus
    9 Oct 2003
    most monitors have a 3 year warranty.
    Frankly, it sounds faulty.
  7. unknowngamer
    unknowngamer here
    3 Apr 2009
    + if you got it new it should be under warranty.
    Even if it's out of warranty, kick up a stink (In a very polite way) and say it's cost £xxx I'd expect it to last for more than 16 months.
    It is not fit for purpose and under the sale off goods act I want a refund.
    The reply will be, 12 month warranty blah blah blah.
    just insist that 12 month warranty is not the issue, It's the sales off goods act 1979 clearly states that goods should be fit for purpose. 16 months is not fit for purpose with or without a warranty.
    As the sale is a contract between your selves and me. It is up to you to honour it, and under the sales off gods act I'm entitled to a refund...
    then go for a compromise.
    If they were going to refuse you've lost nothing by trying.
  8. capnPedro
    11 Apr 2007
    Pics?
    Probably the backlight going.
  9. Golygus
    9 Oct 2003
    according to the hannspree site, the LCD-TV's (and I'm assuming monitors) have a 2 year warranty.
    Your statutory rights cover you with respect to the place you bought the monitor from. The manufactures warranty is extra and they do not have to provide one.
    Port of call:
    United Kingdom
    RepairTech Ltd
    Tel: +44 (0) 871 855 2424
    Fax: +44 (0) 1926 810052
    E-mail: hannspree@repairtech.co.uk
    thehippoz likes this.
  10. PortalBen
    22 Nov 2009
    Thank you very much for all your help :D
